Let There Be Light!!!
Old Nov 12, 2007 | 02:36 PM
  #106
haloman's Avatar
Originally Posted by motomac3
yeah every body went and bought some and ran them out of stock. i would call them and see when they might get more in.
I called Maryland Metrics and they said they had to have at least $50 bucks between orders to get them from Flosser. So if there are enough orders (not just $50 on one order) to total $50 they can order them.
http://mdmetric.com/prod/flosser/flosserprice.htm
Old Nov 12, 2007 | 02:39 PM
  #107
motomac3's Avatar
there you go......i know theres like 3 or 4 guys already on here wanting them. wouldnt really be a group buy if you were all just putting your orders in somewhere. i just figured it had to be a $50 minimum order to place. they are cheaper there too. only $5
Old Nov 12, 2007 | 04:51 PM
  #108
Sunir's Avatar
Originally Posted by oil-burner
no other bulb comes close to the light output or quality of a PIAA bulb, have these in everthing I own. Most people won't spend $70.00 for a pair of bulbs, but there is no comparison. Also check out there wiper blades, again nothing comes close. http://www.piaa.com/Bulbs/Bulbs.html
scot
I got the 9007 PIAA p/n 19617 pair...xtreme cool blue white light 4000K bulb pair, they were around $70...they are the 9007. They are 65/55w but they illuminate with the brightness of 120/110w (without the associated heat)
I wanted to put them in my standard beam sockets...can I put them there, I have a Sport so the standards are 9004, and the highbeams are 9007's, is that correct?? The guy from Summit Racing said they will work on my standard beam. Is this correct?
I went to an autoparts store and looked at the backs of 9004's and 9007's and they looked the same ...with the 3 prongs there in staggered fashion...I looked at these PIAA's and they looked the same...think these will fit/work fine??
Old Nov 13, 2007 | 04:30 PM
  #109
supr's Avatar
Can you run these bulbs as is, no new harnes? No melted switches?
Old Nov 13, 2007 | 04:54 PM
  #110
motomac3's Avatar
yup, been running mine now for about 3 weeks. didnt do any thing but stick them in. headlight switch hasnt even gotten warm
Old Nov 13, 2007 | 05:05 PM
  #111
supr's Avatar
Are they backlogged for the bulbs? this may be the most cost effective simple mod ever!
Old Nov 13, 2007 | 06:50 PM
  #112
motomac3's Avatar
not sure, you can call and ask. if not there are a couple of guys on here wanting bulbs but they are out. there is another site that can get them but they need a minumum of $50 worth of orders to get them. sounds like there are already enough of you wanting them that if you all ordered through them you would meet there criteria. cheaper there too. only $5
Old Nov 13, 2007 | 07:12 PM
  #113
swmnkdinthervr's Avatar
Anyone else wanting to go in on em post up...
Old Nov 18, 2007 | 07:38 PM
  #114
haloman's Avatar
Weeks Update! :
So I have had these for about week now. So enjoyable. I have adjusted them a little. I drive in town with just low beams. Out in the county lows plus fogs equal perfect light for me. Thanks again to everyone for the help, best upgrade I have done so far.
Old Nov 18, 2007 | 09:12 PM
  #115
dieselman2300's Avatar
Im up for a set.
Let me know.
Old Nov 28, 2007 | 05:59 PM
  #116
haloman's Avatar
Bad News: One of my flosser low beams burned earlier in the evening. I guess I am going back to Silverstars. I am not blaming the bulb, I didnt try to touch them when I put them in put I may have I dunno.
Old Nov 28, 2007 | 06:22 PM
  #117
roadranger's Avatar
Originally Posted by caper
I just reach in and replace my bulbs , and I have very big hands and its tight , instead of removing the light , are some trucks different ???? Takes me about 1 min to change a side. I guess I'll have to try these bulbs also sinse I just ordered the HD wire kit.
Yeah, how'd ya do that?
The batteries are in the way...
Let us all know!
Old Nov 28, 2007 | 06:24 PM
  #118
haloman's Avatar
Let us all know!
It takes some trying. I just did it and I have big hands.
Old Nov 28, 2007 | 06:47 PM
  #119
dieseldork's Avatar
HALOMAN you mean you burned out one of those bulbs that are only a couple weeks old . What gives
Old Nov 28, 2007 | 06:52 PM
  #120
haloman's Avatar
I dont know what happened to it. Maybe I touched it but I made it a point not too. I am going to run my sileverstars and see if they burn out incase its a harness issue, but I doubt it.
