Let There Be Light!!!
Old Nov 11, 2007 | 04:50 AM
  #91
dieseldork's Avatar
Hey halaman did you wire up your 9104's so you can run the high's and low's both at the same time ?
Old Nov 11, 2007 | 02:48 PM
  #92
motomac3's Avatar
Originally Posted by oil-burner
no other bulb comes close to the light output or quality of a PIAA bulb, have these in everthing I own. Most people won't spend $70.00 for a pair of bulbs, but there is no comparison. Also check out there wiper blades, again nothing comes close. http://www.piaa.com/Bulbs/Bulbs.html
scot
i will put these flossers up against piaa any day of the week. piaa make a good bulb but you pay for the name with them. not to mention i can buy these flossers for the rest of my life for what one twin pack of the piaa's cost. these floosers are so bright i dont even use my high beams anymore.
Old Nov 11, 2007 | 02:49 PM
  #93
motomac3's Avatar
i would not recommend doing this as the heat would be tremendous.
Old Nov 11, 2007 | 03:57 PM
  #94
Doj Dewd's Avatar
Originally Posted by haloman
I got These:
Click Here
Worked just fine and bolted right up
did you have ANY problems mounting these at all, i have heard on here that many guys have had problems with the one piece designs & their fitment in place of the two piece.
do you know who the manufacturer is? possibly JDM or KS?
Old Nov 11, 2007 | 04:00 PM
  #95
haloman's Avatar
No problems mounting them. I'll get some pics when it clears up here. There might be problems with other designs but not the ones I purchased. they came from option racing, I believe.
Old Nov 11, 2007 | 04:27 PM
  #96
fordkiller43's Avatar
they are outta stock!!!!! I will keep my eye for em tho.
Old Nov 11, 2007 | 07:47 PM
  #97
taken5875's Avatar
the bulbs are out a stock as well I ordered them a week ago and when I placed the order the bulbs were flagged as limited. minutes after I ordered them I received an email stating that they were [COLOR="Red"]BACK ORDERED this makes me sad.........
Old Nov 11, 2007 | 08:33 PM
  #98
EverydayDiesel's Avatar
anyone know any details on the wiring harness??
I assume it just takes the control wire from the switch on the dash, runs it into a relay 85, and then uses 30 to go from the battery and 87 to the head lights +12v wire
am i right on this? basically were just taking the load off the circuit from the dash
Old Nov 11, 2007 | 08:47 PM
  #99
motomac3's Avatar
here are what the 4 posts on a relay are for.......
30-power source(batt)
85-ground
86-switch wire
87-to the lights
Old Nov 11, 2007 | 08:57 PM
  #100
haloman's Avatar
The harness is two new sockets for the bulbs, and socket to plug into the stock harness to trigger everything and two relays. I added two 30 amp fuses to it per Dr. Evil's reccommendation
Old Nov 12, 2007 | 12:17 PM
  #101
haloman's Avatar
Pictures of the lights installed:
Old Nov 12, 2007 | 12:50 PM
  #102
Dr. Evil's Avatar
They look Awesome...how do they work?
Old Nov 12, 2007 | 01:05 PM
  #103
haloman's Avatar
Yes they seem to be. I think I might adjust them down a bit to get it perfect. But driving with these lights on low beam is awesome. I dont need my fogs or high beams. I turned them all on (highs,lows,fogs) on the way home and it was INSANE, I dont need that much light at all.
Thanks. See earlier post. With more time in the seat, I enjoy every minute so far driving at night with this setup. Lets see how the longjevity of it is.
I do want to go ahead and thank Motomac3, Dr. Evil and Sea Drive :/> for all the headlight advice and all of the past threads I have read on this subject.
Old Nov 12, 2007 | 01:54 PM
  #104
Goalie990's Avatar
The website u gave says they are out of stock
Old Nov 12, 2007 | 02:00 PM
  #105
motomac3's Avatar
yeah every body went and bought some and ran them out of stock. i would call them and see when they might get more in.
