Let There Be Light!!!
Old Mar 2, 2008 | 06:07 PM
  #256
haloman's Avatar
Flosser sells a 9107 bulb that is higher output for the sport models, so you can get a 9104 and a 9107
Old Mar 2, 2008 | 10:47 PM
  #257
torquefan's Avatar
Originally Posted by firemanram
Why is it a big deal to use a HD harness? I am wanting to know because I want to install new bulbs.
The HD harness offers a big improvement, especially using bulbs that draw more current, because the stock headlamp wiring is only marginally heavy enough, and there is considerable voltage drop by the time the current reaches the bulb.
When I installed my relay harness, I hooked the power lead right to the charge terminal on the back of the alternator to achieve even less voltage drop.
I found on my Summit harness that the relays were of extremely poor quality. They failed soon, and having an uncommon footprint I couldn't find a direct replacement, so I installed common ISO relay connectors to the harness and installed decent Bosch relays.
Old Mar 4, 2008 | 11:42 AM
  #258
Dr. Evil's Avatar
One of my relays on the LMC harness died this morning...
Anyone have a source for relays (I havent looked yet but thought one of you guys might have the info handy).
Old Mar 4, 2008 | 11:43 AM
  #259
haloman's Avatar
Should be a standard relay you can source at any local electronics store (I.E. Radioshack)
Old Mar 4, 2008 | 01:49 PM
  #260
Sea:\>Drive's Avatar
I buy in bulk off fleaBay. They all basically come from the same factory in China anyway. Only ever had one out of probably 50 go bad on me. Buy extras since they are cheap.
Old Mar 4, 2008 | 03:29 PM
  #261
sheriffav8r's Avatar
Dr. Evil, Try here: http://www.partsexpress.com/pe/showd...number=330-073
They also have a 330-070 for about $2.50
On an aside, I used an old private airplane owner trick on my plastic headlight housings. Clean them with gunk remover and then apply a nice coating of Lemon Pledge! Wipe away the excess and you are left with a fairly clean lens! This is used on plastic aircraft windows to remove the yellow and keep bugs off and I think it helps a lot!
Old Mar 4, 2008 | 04:20 PM
  #262
Dr. Evil's Avatar
Thanks guys...
Old Mar 17, 2008 | 11:46 AM
  #263
dieselbeef's Avatar
Muted User
nobody had anything to report on lites after this....its my next upgrade after the towing mirrors...i cannot wait for them. woohoo...then the headlites. been awhile is everyone still happy with what they ended up running??
Old Mar 17, 2008 | 11:47 AM
  #264
haloman's Avatar
I am happy with my setup still working wonderful. I think everything got left off at Flosser will send you replacements if your blows.
Old Mar 17, 2008 | 11:52 AM
  #265
dieselbeef's Avatar
Muted User
glad theyre good but i dont know bout the '''got left off at flosser thing''... you mean the bulbs? i understand the new sylvanias are the latest greatest...know anything bout them
Old Mar 17, 2008 | 11:54 AM
  #266
haloman's Avatar
The flossers are the upgraded bulbs talked about in this thread. Some guys had problem with them blowing. I have the latest Sylvanias i like them alot.
Old Mar 17, 2008 | 11:56 AM
  #267
dieselbeef's Avatar
Muted User
cool....im goin with them and the sport setup i think....or maybe just the standard lites . i dont know but theyll be sure better than what i got i know that
Old Mar 17, 2008 | 11:59 AM
  #268
haloman's Avatar
I thought about going sport but it was too much modification and costly for my taste. My thought was that I can go back to stock easily with my setup and fix nearly any problem in a auto store parking which I didn't feel like I could with other options.
See here for all the details:
https://www.dieseltruckresource.com/...d.php?t=189530
Old Mar 17, 2008 | 12:03 PM
  #269
dieselbeef's Avatar
Muted User
cool halo. thanks bud. ya know after lookin at yers i think ill just get the stock replacements in clear like yers.
you have the relays on yers too right.
sorry im asking but i didnt read the whole thing..just lookin for updates on stuff
Old Mar 17, 2008 | 12:15 PM
  #270
haloman's Avatar
Thats cool, I have:
Ebay housings
Relay harness from lmctruck.com
Silverstar Bulbs
Still going great, No leaks or anything after a winter of use.
