Larger down pipe for stock turbos????
Old Feb 24, 2007 | 03:03 PM
Muskys TD's Avatar
Question Larger down pipe for stock turbos????
I was looking into getting a larger downpipe for my 95, but is it worth it with the stock turbo??? I believe the turbine exducer is only 2.25" and the downpipe on the truck is 3" OD. It doesn't seem like going to a larger downpipe with have any benefit at all. The reason I'm asking is because I'm planning on installing a electronically controlled exhaust cutout before the cat, and I want to know if I should go to a larger downpipe. The truck will have the following mods: cold air kit, 3000rpm GSK, #8 plate, then bump up the boost and tune it on the dyno
Old Feb 24, 2007 | 04:20 PM
wcbcruzer's Avatar
Naw, there's no benefit on a stock truck. Anything larger than 3.5" to 4" is going to hurt performance by slowing down your turbo spool time.
Old Feb 24, 2007 | 07:21 PM
Muskys TD's Avatar
The truck won't be completely stock. I am going to be installing a cold air kit, 3000rpm GSK, #8 plate, then bump up the boost and tune it on the dyno. Will there be any benefit with a larger downpipe??
The diesel world is new to me. On turbo powered gasoline engines a 3inch exhaust would be more then enough when the turbine has a 2.25inch exducer. Are these diesels any different??
Old Feb 24, 2007 | 07:29 PM
blackdiesel's Avatar
Registered
are you just going to a larger DP or a whole larger exhaust system? just the down pipe wont do you any good, but if you steped up to a complete 4" system you should recieve a drop in egt's
Old Feb 24, 2007 | 07:51 PM
Muskys TD's Avatar
I'm going to install a exhaust cut-out before the cat so there won't be any back pressure from those items.
Old Feb 24, 2007 | 08:17 PM
wcbcruzer's Avatar
A 4" exhaust is good for up to 500 hp. A full exhaust will give you a drop in egt's. Not that you'd reach critical temps. with your mods anyway. You might benefit a little by going with a 3.5" downpipe (as far as lowering your egt's a tiny bit), but anything bigger is pointless. Might as well save your money.
BTW: with the cutout, your truck is going to be loud!
Old Feb 24, 2007 | 10:43 PM
NoSeeUm's Avatar
Why does the larger exhaust slow spool time?
Jim
Old Feb 24, 2007 | 11:06 PM
wcbcruzer's Avatar
I guess it has to do with the velocity of the exhaust gasses. The larger the diameter of the pipe, the slower the exhaust gas moves out, the more time it takes to get the turbine wheel spinning.
mattmanj2001
Dec 11, 2010 07:33 AM
Jordan5687
Feb 14, 2007 05:00 PM
dditt0635004x4
13
Feb 7, 2007 12:36 PM
1320
30
May 31, 2003 01:01 AM
