keeping intercooler boots on
I have one boot that I keep popping off. It a silicon one with equal torque clamps on it. Its on the cold pipe of my twins. Any secrets to keeping these things on? Is there anythign I can use to make it stick better?
Thanks
Thanks
piers told me i wound need to use a nonwater based epoxy on the lower boots and keep the upper boots clean so you could keep them able to take off......thats if i was to go over 60psi
Hairspray always works for me.
The cheapest brand you can find the better.
Are you using a torque wrench on the clamps?
The clamps need to be much tighter than most people would do by feel alone.
That's a very bad idea. That might cause a run away engine and destroy your engine. Put soapy water on the intercooler boots and see if you see any bubbles. Or pressurize the system to about 20-30 psi and see if you hear any air leaking.
mullishacrew
Oct 30, 2008 09:29 PM
13ALPHA
Apr 28, 2008 10:42 AM
Palmetto_kid
Nov 13, 2003 05:57 PM
Cumminsdieselboy
Jul 8, 2003 12:58 PM
