code 0216 and 0219
Old Aug 16, 2005 | 11:24 AM
ridofpwrstroke's Avatar
code 0216 and 0219
does this mean the pump is bad? I left the comp plugged in, should I unplug the comp to get accurate readings? What is the 0219?
Old Aug 16, 2005 | 11:26 AM
2500Ram's Avatar
P0219 Engine Overspeed
from
Here
Old Aug 16, 2005 | 11:37 AM
CTD NUT's Avatar
The 0216 DTC is the IP timing failure code....it means some of the VP44 electronics are working intermittently.......it is the typical VP44 death code. The Comp will have no effect on how the PCM stores codes - it will not matter if it is pluuged in or not.
Old Aug 16, 2005 | 12:15 PM
is this a problem that is warranteed from dodge or do I have to wait for it to fail altogether?
Old Aug 16, 2005 | 12:18 PM
Geico266's Avatar
Take it in right away and get them to log the code and problem.
Old Aug 16, 2005 | 12:19 PM
will they fix it, or just log it. I only have 48k miles on it.
Old Aug 16, 2005 | 12:22 PM
CTD NUT's Avatar
The 0216 DTC is enough to justfy warranty replacement of the VP44 but make sure to leave no evidence of the Comp as it will void the warranty even though it has nothing to do with this failure.....this isn't by chance for your 02 is it? If so, I think you can forget about engine warranty altogther! I would think the twins would scare most any dealer away!
Old Aug 16, 2005 | 12:28 PM
my dealer takes pretty good care of me. I hope they will on this as well.
Old Aug 16, 2005 | 02:10 PM
CTD NUT's Avatar
Wow....that is a great dealer if they are willing to overlook twins and a Comp when it comes to engine warranty issues!
Old Aug 16, 2005 | 02:11 PM
how do they know that I have a comp?
Old Aug 16, 2005 | 02:48 PM
RustyJC's Avatar
One of the things that DC STAR specifically requires the dealer to look for is a pierced pump wire. If you've pierced the wire, not even a cooperative dealer will be able to replace the VP44 as STAR will reject the warranty claim when they get the pump.
Rusty
Old Aug 16, 2005 | 04:51 PM
blue chip cover
KustomAutoBody
Mar 8, 2007 05:54 AM
HOdiesel80
Jun 10, 2005 07:53 PM
scuzman00
Sep 7, 2004 10:00 PM
TE-44
Jul 31, 2004 10:29 PM
j
Mar 9, 2004 11:45 AM
