kdp
Old Nov 11, 2009 | 06:36 PM
Schneider's Avatar
kdp
so i am wondering would your kdp let your engine leak oil cause i am leaking oil but not relly sure where from.
Old Nov 11, 2009 | 09:51 PM
Dr. Evil's Avatar
Yes, if the dowel pin cracked your timing case or cover you could have a fairly large oil leak (which could be the least of your worries) - get the KDP fixed ASAP.
Old Nov 12, 2009 | 09:10 AM
Schneider's Avatar
im not sure if that is it i am leaking oil on the drivers side im not really sure where at tho. kinda by my injection pump or somthing
Old Nov 12, 2009 | 11:10 PM
Plumb Wild's Avatar
These trucks develope lots of oil leaks with age. Not always much to worry about...assuming its just a gasket weep or something similar.
Old Nov 13, 2009 | 12:37 AM
Dr. Evil's Avatar
Are you sure its not fuel?
Old Nov 13, 2009 | 06:46 AM
Schneider's Avatar
no its not fuel cause it is black.. o well thanks for the help ill try to find the leak.
Old Nov 13, 2009 | 07:24 AM
b.lee's Avatar
Does it leak a puddle overnight?
Old Nov 13, 2009 | 10:13 AM
Tow-mater01's Avatar
most common gasket failures on that area of the engine are front main front cover or vacuum pump gasket... if the kdp got thrown into the gear case then you would see the hole (it makes a hole big enough to put 2 fingers in) if you think its cracked there put some jut lube or ether on it dry it up clean it off to see to be safe id pull the front cover just to be sure and replace gaskets as you go...
Old Nov 13, 2009 | 12:52 PM
Schneider's Avatar
it prob drips about the size of a half dollar not big tho... thanks for info about the gaskets ill make sure and replace them.
sootnsmoke
Jan 5, 2012 08:55 PM
Smokin96_12v
Oct 12, 2009 07:39 AM
SjLingenfelter
Jul 19, 2003 05:14 PM
WalkingHorse77
Mar 19, 2003 12:27 PM
gofastman
Mar 19, 2003 10:29 AM
