Just another lift pump discussion.... :)
Well I know there are a million different opinions about lift pumps/fuel systems. I just figured I would post my recent experience with a different setup. I got the vulcan relocation kit, and ordered a carter HP black pump, from summit. Heres a LINK
I put this pump in and my fuel pressure has been a steady 26psi at idle and Ive only been able to pull it down to 19psi. The install was especially easy since this pump is exactly the same dimensions as the factory lift pump. Im very happy with this setup. For under $200 Ive got excellent fuel pressure now. Im sure this pump could be run with the factory lines and still obtain great results, I just decided to up grade to the bigger vulcan lines while I was at it.
My $.02
My $.02
The holley blue on my other truck is unregulated, and has made about 22psi for last year and a half. Im not worried about it, it hasnt caused any problems yet, no hard starts or anything. Im going to keep on running it, if it becomes an issue I'll let everyone know.
I installed the pump on the fuel rail in front of the fuel tank. The fittings worked great, with the vulcan kit. I forgot to mention also that this pump is super quiet compared to my holley blue. Only time will tell if this pump is a good aftermarket replacement, but for just over $100, I'll experiment.
I have had the P4601hp for over a year and just started having problems last month.
My fp went to 8# from 24# and varied then from 6-14#. I put the original lp in line with the 4601 and get 26# at idle and drops to 16# under heavy load, after about 2 hrs pulling my little 5r it dropped to 10#.
The fp goes back up after the truck sits for an hour or so.
Harold
Harold
stock600
Mar 4, 2008 11:09 PM
powerrammaster
Nov 4, 2007 08:20 AM
Jezzhuntin
Aug 25, 2006 02:51 PM
PCarnathan
Feb 18, 2005 07:37 AM
TomW
Nov 18, 2003 12:37 PM
