Ideas
Old Jan 30, 2007 | 07:58 PM
xOmertAx's Avatar
Ideas
Okay, so I'm new here, I filled out the sig, and I want some opinions. I'm looking to have 155 hp injectors, a turbo (I have no clue what yet), and I'll probably out a 5 inch MBRP exhaust...what else would I need, and what kind of clutch do I need to hold all of this? I'll do some sled pulling and i will be hauling about 17 bales of hay at a time occationally.
Old Jan 30, 2007 | 08:00 PM
blackdiesel's Avatar
Registered
looks like you should get you a set of mach 4's from f1diesel and a south bend double disk from southbendclutch and a sps62 from industrial injection.
Yup, thatll about cover it
Old Jan 30, 2007 | 08:06 PM
xOmertAx's Avatar
alright man thanks. What else should I do to the truck to make it a little more stout...i know a new air intake, I'll probably go S and B.
Old Jan 30, 2007 | 08:10 PM
Registered
well you might look into the smarty. will approve driviability and greatly improve spool up
Old Jan 30, 2007 | 08:19 PM
xOmertAx's Avatar
anybody have anything else? and what's a good SINGLE disk clutch...because i don't want to have to put the bigger input shaft, I'm 15 (about to be 16.) and I'm going to be doing most of this stuff so the less I have to spend the better
Old Jan 30, 2007 | 08:25 PM
Registered
sorry, if you want to sled pull, youll have to do the DD.
sled pulling and single disks dont mix! you'll have to replace it after you smoke it
atc250r
Mar 22, 2003 12:27 PM
JoeDiesel
Mar 13, 2003 06:36 PM
FloridaTruckLover
Nov 28, 2002 08:20 AM
tomsauto
Nov 19, 2002 07:18 PM
