Juice
Old Jul 4, 2006 | 02:17 PM
CTD01's Avatar
Juice
Ok i got the juice with the attitude. I didnt tap the pump yet, I got the hot unlock code, does any one know about what my power increase is? What does the chip adjust at the different levels, boost, fuel deliver, timing, ect. Will I get more smoke with the pump tapped? I saw something in the new Diesel Power and it said that the juice with the attitude did high idle and prevented tranny slip is this true? TIA
Paul
Old Jul 4, 2006 | 04:05 PM
bowtiestrkrsmkr's Avatar
I have an 02 with the juice and the "HOT" unlock and I can tell you that there is a big difference in performance. I know that if you do end up and tapping the wire you will really notice it. I never ran mine without it tapped, but I can tell you that you will not get the full effects of the box without it being tapped. With the wire being tapped you it is allowing the box to add more fuel, otherwise I am pretty sure all the it is doing is adjusting the timing and raising the boost.
Rick
Old Jul 4, 2006 | 09:31 PM
KVD's Avatar
KVD
What all does the juice do?
I know EGT, boost, turbo timer, and I think fuel pressure but what else??
Old Jul 4, 2006 | 10:03 PM
speed, tach, trans temp, boost, fuel pressure, egt's, fuel temp, and intake temp. That is all I can think of right now
Rick
Old Jul 4, 2006 | 10:41 PM
CTD01's Avatar
Juice
Does the juice do anything for my tranny line presser ect. I was looking at a superchip and it says the it changes the shift points and increaes line pressure. If my chip doesnt do this then what can I do to change my shift points and increase my line pressure? TIA
Paul
5.0 Mustang Man
Oct 21, 2008 02:50 PM
SconsinSmoker
Feb 12, 2007 09:15 AM
bighornram
13
Nov 2, 2006 08:28 AM
razor6
22
Jan 20, 2006 03:43 PM
djcheez
Oct 15, 2005 04:13 PM
