The invincible head gasket is now dead
Old Feb 18, 2007 | 12:17 PM
TxDiesel007's Avatar
LOL
just had to share that with u fellas. After what i had put the thing thru, im surprised that it held for as long as it did..
I had started another post in the 12V forum on a leaking thermostat housing, well aside from that leaking, and removal of the alternator i see that my leak was also stemming right below the T stat housing where the HG is at.. (insert your favorite colorful word here....) I guess its time i stop dinkin around and put some ARP's and a 10 over gasket..
Rick
Old Feb 18, 2007 | 12:20 PM
BigBlue's Avatar
That sucks rick. Hope you get it all back together before the dyno. I should have my studs installed this week.
Old Feb 18, 2007 | 01:07 PM
Probly not blue
I start my new job, so time is tight as is everything else, Im probably gonna have it done when im gone off to GA, But im gonna dyno anyways... at least one pull, if it reads over 500 horses im good...
Good luck with the studs man
Rick
Old Feb 18, 2007 | 01:23 PM
BigBlue's Avatar
Now your sounding like my buddy. Been running a blown headgasket for 6 months now cause he just won't fix it.
Old Feb 18, 2007 | 04:00 PM
12valve's Avatar
WOW, i see a "popped head gasket" thread almost every day! now a head gasket popped on our truck just where it did on your truck, but never started a thread about it... What causes it to pop outsiede anyway? what Boost pressure where you running?
We where running 42 psi max out of the Htb2 64
we replaced it by a HG that costed us $60 from FP diesel it has worked great so far and use the truck hard and a lot!
my question what gasket do you guys put in? cause you all worry so much about it!
Old Feb 18, 2007 | 04:19 PM
Mine popped probably
at 40-50 psi, but it had been a long time comin, i have dynoed, raced, pulled, and hauled heavy loads with it, so i cannot complain, it did well, i started another thread on what HG to buy, i wanna do this once and do it right..
Rick
Old Feb 18, 2007 | 04:50 PM
signature600's Avatar
That sucks Rick
For some reason or another, the one on the old 95 is still hangin' in there...ran at 48psi with the stocker, then 38psi with the B1, 63psi with the BD Twins, and maxed at 76psi with the HX40/B2 twins, then I turned it down to 60psi and ran it, and now it's holding 45psi with the S300 All this over the course of 130K miles and 2.5 years on stock bolts and gasket with 330K miles! That thing won't die
Hop you get it fixed up quick!
Chris
Old Feb 18, 2007 | 05:14 PM
dieselfan's Avatar
Originally Posted by signature600
That sucks Rick
Chris
did you re torque them?
Old Feb 18, 2007 | 05:18 PM
haloman's Avatar
It seems these things happen at the worst time. But I hope you can get it fixed up right.
Old Feb 18, 2007 | 05:27 PM
Nope! Never touched them. I would run it hard, then get out at stop signs and check it for leaks...I was so sure I'd pop it
Chris
ted_pulliam
Jul 16, 2009 11:33 AM
wildchild97
Sep 25, 2007 02:44 PM
BigBlue
61
Oct 7, 2006 08:03 PM
Hoss
Aug 27, 2006 01:10 AM
BigBlueDodge
13
May 3, 2006 02:55 PM
