installed Edge EZ
Old Jan 16, 2004 | 10:17 AM
Palmetto_kid's Avatar
thanks J. I'll try and reset it during lunch today.
Old Jan 16, 2004 | 10:56 AM
BLUTIC's Avatar
I thought mine ran good with DD2's, but when I got my puck installed, it really packs a punch. I see alot more smoke too.
Old Jan 16, 2004 | 06:28 PM
tomrock's Avatar
Got a lot of punch out of the EZ...MUCH more smoke than without it...alot more pep...find someone and use another, see if yours is toes up...
Old Jan 16, 2004 | 07:38 PM
RATTLINRAM's Avatar
Thumbs up Big difference in mine
I bought a slightly used EZ from the Smurfs and it makes a big difference in my 99. Papa Smurf put mine on while we were at the dragstrip in NC and I went straight out onto the track. I have lowered my best ET by between .5 to .75 of a sec. It was hard to tell that day since I had a problem with leaving the line without roasting the tires. It was also the first time I've ever heard the rear tires chirp when the auto hit second.
I have also found out that I need to be careful about nailing the throttle to the floor at speeds under 55 in OD because I can hear/feel the tranny wanting to slip. As long as I ease into it and make sure the rpms are up, there isn't a problem.
With the boost elbow, I can see 32-34psi at WOT. You can definitely feel the increase in torque! Now I have to start saving for some tranny upgrades.
Old Jan 16, 2004 | 08:37 PM
Haulin_in_Dixie's Avatar
Thumbs up big difference in mine too
I put the EZ on first, a couple of days later the RV275's. Both times I came home with the grin on my face.
Old Jan 18, 2004 | 03:40 PM
More Power's Avatar
I put an ez an my ho 6speed and it alone would smokein all gears at low boost below 10psi and with dd2's now it smokes whenever the trottle is down. I did notice a considerable difference with just the ez.
Old Jan 19, 2004 | 06:58 AM
Made a long haul this weekend. I noticed my mileage was better, and I know the EZ is working. I smoke very little. It only smokes taking off in first and second. I really notice the difference in the top end.
the only thing I am concerned about is a whine that comes from my turbo at boosts above 24 PSI. what could that be?
Old Jan 19, 2004 | 07:40 AM
More Power's Avatar
The faster you turbo spins the louder it is and some big injectors get you boost up to about 38 on that turbo and it really starts to make some noise.
Old Jan 19, 2004 | 07:35 PM
yrusoslow2's Avatar
Palmetto_kid,
I just got on the computer since the last time that I talked to you. You were starting to scare me. I know that ez box was working good when it was taken off. If you have any problems let me know. Could the noise you hear above 24 psi of boost be the small bleed hole in the boost elbow. That may be it. Well let me know how everything is working.
Justin
Old Jan 19, 2004 | 09:49 PM
I think he is just hearing the turbo wind up. I could not hear mine, even with the ScottyII until I installed the EZ. A lot of times for economy I drive by it, trying to keep it below turbo wail. Works too, gives me another mpg when empty and weighing 14,650 gross.
Old Jan 20, 2004 | 11:40 PM
bennydodge's Avatar
Originally posted by Shovelhead
I've heard that the HOs don't see as dramatic an increase as the Standard Output folks.
Could that be the case?
Ed
*EDIT BY ADMIN: Click Here* no. My HO was a WHOLE different truck after the EZ. Night and day difference
Old Jan 22, 2004 | 05:16 PM
Floorman's Avatar
hey guys listen when i installed mine i didnt think it was all there either til i sat in the passenger seat and let my buddy lay into it. i had driven a reg cab so the weight plays a role. i just unhooked it and took it to the dealer 30 min ride boy did i notice it was missing.
rjm022
Nov 23, 2006 11:29 AM
Hoss
23
May 25, 2004 05:54 PM
Bradley
Dec 9, 2003 12:06 AM
Cat Cracker
Oct 4, 2002 04:04 PM
