Innercooler
Old Jan 2, 2005 | 01:21 AM
BDR2500's Avatar
Innercooler
i was wonderin about the stock innercooler, when I run twins will the stock innercooler be ok? I was shoppin around and found that Haisley Machine has an aftermarket 100 psi innercooler, would this be something to look into? Thanks guys
Old Jan 2, 2005 | 07:19 AM
chevota01's Avatar
The question is how long will it last. Pushing in the 58-68 psi range did mine in within 3 months. That's including towing a fifth wheel and just daily driving. If you plan on taking any extended trips I would say do it with the twin install. FYI - mine was blown in the typical lower passenger left corner and the truck was still operational until the swap - runnable but not reliable.
Old Jan 2, 2005 | 08:09 AM
Jim Fulmer's Avatar
I finally blew my stocker and went with PDR custom bolt in unit, not only will it handle the pressure it's a much better cooler.
Jim
Old Jan 2, 2005 | 08:22 AM
infidel's Avatar
Stock cooler is rated at 50psi
Old Jan 2, 2005 | 05:04 PM
BDR2500's Avatar
Thanks guys
Old Jan 3, 2005 | 09:42 AM
RowJ's Avatar
I bgt a Haisley when my stock intercooler developed serious leaks from 50 psi boost. I am very impressed with the construction and the quality! The Piers unit was not on the market at that time. Suspect it is at least as good, but have not seen one.
RJ
primal13
Aug 15, 2010 08:58 AM
jesussaves
Aug 14, 2010 02:06 PM
1 grumpy
May 24, 2008 07:03 PM
tankeryanker
Apr 23, 2006 01:51 PM
ramguy
Aug 28, 2003 11:07 AM
