innercooler boot
Old Aug 8, 2010 | 08:38 PM
primal13's Avatar
innercooler boot
hi ya'll,
i just blew a hole in my driver side innercooler boot. no one else carrie's it, so i called dodge and they want $175 for a piece of rubber! they sure are proud of there part's. i found a site called mr. bob's. they sell a four piece kit with two boot's and the upper's. it's about $250 for it, and it come's with new clamp's. does anyone have these, or know about them? i talked to bob, he was a nice guy and helpful. also is there any other place to get these boot's? thank's for the help.
Old Aug 9, 2010 | 09:38 AM
infidel's Avatar
I buy them here> http://www.pdrdiesel.com/catalog/Int...amps-29-1.html
Old Aug 9, 2010 | 10:41 AM
CarlJensen's Avatar
Also, if you had a hole in the drivers side check your fender sheet metal down next to the boot. When boot expands, and it does quite a bit, it hits the sheet metal and rubs a hole in the boot. I bent mine down into a curved shape away from the boot. No more rub!
Old Aug 9, 2010 | 03:12 PM
skog8301's Avatar
i,m not sure but could you go to a truck shop and check if they have that size boot i belive the shop i work at has them
Old Aug 10, 2010 | 06:39 AM
primal13's Avatar
thank's ya'll for the help. carl, i'll check on the metal rubbing part. infidel, thank ya for the link. skog, i'll call some of the shop's around here.
Old Aug 10, 2010 | 08:46 AM
Wyoming Geezer's Avatar
Jegs has complete set with new clamps for about the same price (I think BD). I blew my original boot out of turbo just after my Edge upgrade. 6 years and no more leaks.
Old Aug 11, 2010 | 07:17 AM
CarlJensen's Avatar
Get the new boots with better clamps, and make sure every thing is CLEAN when you put it back together. Use cheap hair spray to aid install and help seal the new boots. Make sure the torque on the clamp bolts is right, hard to tell by hand.
Old Aug 12, 2010 | 08:57 AM
primal13's Avatar
thank's again guy's. silicon intake's has 4" to 3" hose for $20 a piece. i'm going to try them to see what happen's. i'll make sure to torque them right.
Old Aug 12, 2010 | 06:53 PM
infidel's Avatar
Straight hose won't work, it has to be a 3x4" - 22.5* elbow.
That makes them special and pricey.
Old Aug 13, 2010 | 10:50 AM
primal13's Avatar
they make one that's 4" to 3" with a 45* bend. would a 45* versus 22.5* bend limit the the flow any? i don't think it would matter much, but you never know.
Old Aug 15, 2010 | 08:58 AM
infidel's Avatar
I think you'll have a very hard time installing the 45* boot but could give it a try.
It's sort of hard even installing the right boot.
95black2615
Oct 8, 2008 03:34 PM
1 grumpy
May 24, 2008 07:03 PM
tankeryanker
Apr 23, 2006 01:51 PM
BDR2500
Jan 3, 2005 09:42 AM
ramguy
Aug 28, 2003 11:07 AM
