Injectors too big??
Injectors too big??
I want to put some injectors on my 98 24v that's stock. Are 200hp injectors going to be too big, or should I go with some 150hp?
...All I plan on doing for this truck is a tuner besides the injectors.
Thanks,
Thanks,
Your tranny won't play well with that much power.
A Smarty and a set of Mach 4's (150 hp) dynoed at 400 hp.... but your tranny won't hold that either... for very long!
I would much prefer an adjustable Box that could better control smoke and be turned down to appease your stock tranny.
RJ
RJ
Registered
you will need gauges first ( if you don't already have them). Then like rj. said your tranny and your egt's won't like you at all, if you tow, you will want something you can turn down to keep you egt's in check.
HTS is having a special right now on tc/valvebody combo
http://www.htstransmissions.com/Store.html
Randy
Randy
chopper9451
04-11-2008 09:38 PM
5.9Excursion
07-25-2007 09:42 PM
O.T
06-07-2007 11:55 AM
