Injectors
Old Oct 25, 2004 | 09:59 PM
ramtd02's Avatar
Injectors
Wanna get a new set of injectors....currently running stock. I am getting a new tranny, and turbo in may, so i need too start shopping around now. Which ones should i try??
FYI I want something that will give me a good bunch of power and smoke....but if i dont have my foot buried in the coal will still give me a half decent fuel mileage.
Thanks,
Jon.
Old Oct 25, 2004 | 11:45 PM
Begle1's Avatar
You can't beat EDM's from F1 Diesel, available from Wildcat or somebody... I think most people here would recommend getting the turbo and tranny first.
Old Oct 26, 2004 | 08:24 AM
RowJ's Avatar
Agree on both points!
With an Edge Comp you are already pushing your stock tranny as far as you can safely go....and then only on lower settings. Any more power could cost you more when you do your tranny...if it makes it to May.
F1's Mach 2's or 3's are the only ones I would consider...when the time comes.
RJ
Old Oct 26, 2004 | 11:33 AM
ramtd02's Avatar
well the comp isnt pierced...thats why the tranny is holding up!!
Old Oct 26, 2004 | 12:31 PM
Transman's Avatar
Okay, here's my experience--Added Don M's mach 1.5's to my setup. Promptly went out & blew the HX 40 turbo to pcs because I was too busy hanging on to the steering wheel to watch the boost gauge (awesome injectors Don!)--somewhere around 48lbs of boost she went bang. Completely my fault. Talked with Rip Rook and decided on a wastegated Dodgezilla turbo. Engine response is awesome, but egt's are out of control--3 to 4 seconds on the throttle and it shoots right past 1500 deg. After talking to Rip, decided to replace the banks level 5 module (160hp-320tq) with a level 3 module (100hp & 200tq). Truck now works great with egt's hitting 1300 max. My elevation is 3900ft, which seems to make a huge difference. Hope this helps ya.
Old Oct 26, 2004 | 12:49 PM
Lil Dog's Avatar
I think you may just have the wrong turbo?... Either that or you don't have enough timing with that "module"..
MHO of course..
Old Oct 26, 2004 | 12:53 PM
Transman's Avatar
Lil Dog,
I definately need more turbo, just don't want to live with the lag on the bottom end. After talking with Rip, we decided that twins were the best option when running the level 5 box, so I'm saving pennies as we speak--*g*
Old Oct 26, 2004 | 01:05 PM
ramtd02's Avatar
thanks guys...still havent deided which turbo too go with....I am at 2000 ft. of elevation and want one that will keep egt's in check with injectors and the comp on 5X5. I was thinking of a ksb1-2 and running it at 45 psi. But not sure. Any suggestions or should i start another thread??
Old Oct 26, 2004 | 01:34 PM
Transman's Avatar
Ram,
I suggest you call Rip @ 1-866-211-1533.
Old Oct 26, 2004 | 02:32 PM
Lil Dog's Avatar
Transman..
Sounds good.. Curious minds....LOL...
Ram,
Not to take away from Rip, but Piers is only over the mountains from ya and above the 49th.. Shipping or response is 1 day, no boarder issues.
Old Oct 26, 2004 | 03:11 PM
RowJ's Avatar
Depends on whose Stage 2's you have and what your dynoing at but I think you would run high EGt's with a KSB-1-2 after you pierce the wire. Even at 2000' you'll be toasty over 400 hp!
Piers will know.
RJ
Old Oct 26, 2004 | 10:33 PM
ramtd02's Avatar
well with the hy at 32 psi and i am pushing 249.8 at the wheels with 712 TQ....and egts are sweet...in fact the egts cool at full throttle. And i want that kind of deal after the wire is pireced and the injectors.....any ideas?
KRB
May 20, 2007 06:20 PM
GSP
Dec 11, 2005 12:20 PM
W.F.O.
Nov 3, 2005 10:33 AM
darrenG
Jun 21, 2005 10:24 PM
BIGOKIE
Jul 21, 2004 05:53 PM
