injector advice for my setup
Old Mar 17, 2009 | 06:50 AM
JohnBer's Avatar
geez, you guys are a bad influence...... my truck made 14 years with a stock 160 before i found this site.
? is: what injectors should i upgrade to. should i change out the dv's also? still a stock 160 pump outside of the plate and 3gsk. dunno how far i am gonna go with it. twins may be in the near future(almost have the war dept. talked into it)
Old Mar 17, 2009 | 09:29 AM
dzlfarmboy's Avatar
What do you do with the truck? Prob some DDP 2's or 3's
Old Mar 17, 2009 | 10:38 AM
YOUNG GUNS15's Avatar
DDP2's would be the best up to like 500 hp i think, i wnet all the way and got 140HP injectors, but if you do get large injectors to help fuel the twins your going to need delivery valve upgrades to laser cut or 191, mine are the stock 131 and they dont supply enough fuel to the injectors at high RPM and it pops and blows smoke rings.....
any how good luck with the twins! im building my own set with the stock charger on top of something like a hx52 or a HT3B
Old Mar 17, 2009 | 11:42 AM
BigErksG2's Avatar
im in the same boat... building a hx35/ 3b twin setup. bought ddp4's and put them in before the twins (i got a little excited) but they are a nice streetable injector. my advice is dont buy an injector too small and have to buy another set. you can always detune your truck with the fuel plate and anything past 191 DV's gets smokey (i'm not a fan of trucks that smoke everytime they take off) hope this helps!
Old Mar 17, 2009 | 01:07 PM
dzlfarmboy's Avatar
You sure thats not Timing related poping at high RPM, whats you timing set at. Bigger delivery valves are not always the best setup.
Old Mar 17, 2009 | 10:54 PM
JohnBer's Avatar
its my fishin, go to town rig, tow a 19 jet sled (maybe 2000 pounds) with it is about all. just a fun truck . drag home cars occasionally, nothin long distance.
mostly just after a lil fun with it.
Old Mar 18, 2009 | 02:32 AM
Tate's Avatar
Originally Posted by BigErksG2
im in the same boat... building a hx35/ 3b twin setup. bought ddp4's and put them in before the twins (i got a little excited) but they are a nice streetable injector. my advice is dont buy an injector too small and have to buy another set. !
Good advice. I had my 140ish injectors in my truck for 5 months before I swapped in the bigger turbo. It was great on the stock turbo. For what you plan on doing with the truck, I'd get the bigger injectors from the start. 181 DV's will help with the stumble that 131's will cause with the bigger injectors. You could go to 191 or bigger, but 181's should be relatively to find and will do just as well.
Old Mar 22, 2009 | 10:21 AM
JohnBer's Avatar
well during this decision making process my truck has developed a slight miss.
was on #2 so i pulled the injector and swapped it for #3 just to see. yep miss moved. its bad. the i can hear a faint clacking coming from that injector. so its down till i get new sticks.did a comp. test on 2 and 3 and both were just fine.
Idle egt in gear went from 275 before the miss to almost 400. (pre turbo)
When you say DDP is that dynamite diesel injectors? is there a link by chance, i need to do this soon. fishing season coming up and i need to fix my get to the fishin hole rig!
Old Mar 22, 2009 | 02:05 PM
12v rollincole's Avatar
ya, DDP mean dynamite diesel injectors. never had any, not sure where people by them but here is there site. http://www.dynomitediesel.com/user_p...shtml?page=FAQ
if you get the stage 2s let me know how they are.
Old Mar 22, 2009 | 07:15 PM
DodgenIt's Avatar
Bigerks is right, Id say go with DDP's 110hp at minimum. Those are what im hopin will find their way under my hood soon.
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
ryanihf250
Jan 17, 2008 02:58 PM
Price_Dog
Oct 8, 2007 09:29 PM
Kroner
Jun 19, 2005 10:24 PM
perk
Jan 24, 2004 07:57 PM
