i need more boost
Old Dec 4, 2005 | 09:37 PM
RedRider's Avatar
i need more boost
i am running 22 psi right now, i was wondering how i might be able to add a few more psi of boost. i have the adjustable elbow, but im not sure if im suppose to mess with the scew in it. i think i want to get to about 30 psi. can you all tell me how to get more? thanks
-gary
Old Dec 4, 2005 | 09:47 PM
blackdiesel's Avatar
Registered
if you have the adjustable elbow, adjust it. simple as that
Old Dec 5, 2005 | 05:53 AM
RedRider's Avatar
should i tightent the screw or loosen it?
Old Dec 5, 2005 | 07:20 AM
Registered
tighten it.
Old Dec 5, 2005 | 05:34 PM
mr T's Avatar
add more fuel and you will get more boost
Old Dec 5, 2005 | 09:21 PM
RedRider's Avatar
i got my plate maxed out right now, still got 22 psi. ill try tighten it and let you all know tomorrow. thanks
-Gary
Old Dec 5, 2005 | 09:26 PM
TxDiesel007's Avatar
try pushing
the AFC housing forward, and the starwheel full forward as well. The more fuel you put into the engine the more boost tyou are going to get. You might also want to replace your fuel plate as well, Im not certain if you can push a stock plate to 30 PSI and if that dont work. You might wanna try blocking the waste gate, if a bare minimum, you might get quicker boost.
Tx
Old Dec 5, 2005 | 09:33 PM
RedRider's Avatar
Originally Posted by TxDiesel007
try pushing
Tx
all of thats forward, i have a tst #5 (check my sig). not sure if there is a leak i was going to rig something up to do a pressure test this weekend. but somehow the front screw (not the breakoff) hole stripped, and the bolt wont tighten all the way. would that cause a seal or something to not completely seal or should it be ok. i replaced all the bolts with new ones (hex head) after i found out it was stripped.
-Gary
Old Dec 5, 2005 | 09:35 PM
Intercooler boot?
maybe u got a leak there..
Tx
Old Dec 5, 2005 | 10:23 PM
RedRider's Avatar
Intercooler boot?
Tx
ill check them again, but im sure theyre tight
-Gary
Old Dec 6, 2005 | 08:25 AM
RowJ's Avatar
Tightening the Boost Elbow blocks flow to wastegate, reducing it's ability to open. Block it off completely...see what happens.
If no increase, possible boost leaks. Boot clamps are not the only source of leaks. Pin holes and cuts can be invisible when system is not pressurerized but open up when boots expand.
RJ
Old Dec 6, 2005 | 08:58 AM
Beast2B's Avatar
once you have adjusted the boost elbow, you may want to put a dab of RTV on the screw. I have heard that they can get loose and fall out. No personal experience, but rumor has it...
Old Dec 6, 2005 | 11:49 PM
RedRider's Avatar
yeah i heard that too and was wondering about it. But today tightened the screw and am now boosting 25 psi at 85 mph, and i think if i get on it some more ill boost more. is that normal? but i really dont think i have any leaks.
-Gary
G1625S
May 14, 2012 10:31 AM
mr T
Sep 11, 2005 01:37 AM
vossperformance
Jun 13, 2005 04:15 PM
TE-44
Apr 28, 2004 12:17 PM
j
Dec 21, 2003 10:26 AM
