I got spanked
Old Nov 24, 2003 | 09:00 PM
TE-44's Avatar
I got spanked
I got spanked tonight by a honda civic, you guys know the ones.I tried a second gear start but smoked the rear tires, tried a third gear start but the truck bogged down so hard it all most stalled.The truck is pretty much stock accept for a VA box,14inch K&N cone filter,turbo ring fell off,stock 3inch strait pipe exhuast,3.55 gears.I need to know what needs to be done to this truck so this guy who works somewhere around me see's my tail lights next time we meet. >
Old Nov 24, 2003 | 09:20 PM
blackjack's Avatar
Re:I got spanked
sounds to me like you need to look at your tires. You can have all the power you want but if you can't hook up it means nothing. you are prolly dumping the clutch at too high rpms for your tires. comming out of the hole is tricky when you have as much torque. you need to get the power that you have to the pavement before you add any more power if that makes sense. just my 02
Old Nov 24, 2003 | 09:24 PM
TE-44's Avatar
Re:I got spanked
I tried a third gear start at about 2100 rpm's but the truck just bogged down.The second gear start was at about the same rpm.
Old Nov 24, 2003 | 10:51 PM
PHX_ATC's Avatar
Re:I got spanked
Just run him over, it won't hurt your truck none! What's a little paint on the oil pan?
Old Nov 24, 2003 | 11:26 PM
Jambbii's Avatar
Re:I got spanked
Thats why I like my 4wd, eats rice all day long ;D
Old Nov 25, 2003 | 04:16 PM
HOHN's Avatar
Re:I got spanked
You need more fuel than a VA if you want to race a bit. Try some Mach 3s-- that should be the start of your fuel shortage cure....
HOHN
Old Nov 26, 2003 | 10:40 AM
Ramflasher's Avatar
Re:I got spanked
LMAO! Hence the post about high EGTs?
I'm about to test out some EDMs...I have run 275s, DD3s, and Super Mentals...
Practice a few launches before the next race, and get those injectors and gauges in...he'll see your taillights!
You could always get him on a roll, say part way through your 3rd gear.... ;D
Old Nov 26, 2003 | 11:26 PM
Srigs's Avatar
Re:I got spanked
4X4 will fix that problem! 8)
Old Nov 26, 2003 | 11:47 PM
quantrill88's Avatar
Re:I got spanked
remember also, u drive a nv4500 5 spd........not designed as a racing tranny
Old Nov 27, 2003 | 01:32 PM
Ramflasher's Avatar
Re:I got spanked
[quote author=quantrill88 link=board=7;threadid=22833;start=0#msg214765 date=1069912072]
[/quote]
That is a very true statement!
I have seen Jason Burton (NW Custom) row through his as fast as about anybody I have ever seen....
Old Nov 27, 2003 | 03:18 PM
Rod meyer's Avatar
Re:I got spanked
Rob,what size edms are you gonna try?I know you have 3s now.I have 2s and Iam interested in edms.keep us posted
Old Nov 27, 2003 | 04:04 PM
Captain's Avatar
Re:I got spanked
[/quote]
Oh I dont know. I can shift it about as fast as a stone crusher. My biggest problem is about 10% of the time I miss getting it into third. Guess I need to practice ;D
Old Nov 27, 2003 | 05:44 PM
Ramflasher's Avatar
Re:I got spanked
[quote author=Rod meyer link=board=7;threadid=22833;start=0#msg214980 date=1069967896]
[/quote]
I'm not sure. I need to discuss this more with some people with more knowledge on them than me. I am currently running super mentals. I like them, but for towing my DD3s were better. About the same power and heat, but with the 3s, I got almost 2 1/2 mpg better. That is with 14,000 lbs behind me. Same roads, same weather.
Silver Ram
Feb 9, 2011 12:31 PM
crossy
34
Jan 6, 2006 05:08 PM
rattle_rattle
25
Jan 8, 2004 03:58 PM
torqueman
Dec 29, 2003 09:43 PM
