I got spanked
I got spanked tonight by a honda civic, you guys know the ones.I tried a second gear start but smoked the rear tires, tried a third gear start but the truck bogged down so hard it all most stalled.The truck is pretty much stock accept for a VA box,14inch K&N cone filter,turbo ring fell off,stock 3inch strait pipe exhuast,3.55 gears.I need to know what needs to be done to this truck so this guy who works somewhere around me see's my tail lights next time we meet. >:(
Re:I got spanked
sounds to me like you need to look at your tires. You can have all the power you want but if you can't hook up it means nothing. you are prolly dumping the clutch at too high rpms for your tires. comming out of the hole is tricky when you have as much torque. you need to get the power that you have to the pavement before you add any more power if that makes sense. just my 02
Re:I got spanked
I tried a third gear start at about 2100 rpm's but the truck just bogged down.The second gear start was at about the same rpm.
Re:I got spanked
Just run him over, it won't hurt your truck none! [laugh] What's a little paint on the oil pan? [laugh]
Re:I got spanked
Thats why I like my 4wd, eats rice all day long ;D
Re:I got spanked
You need more fuel than a VA if you want to race a bit. Try some Mach 3s-- that should be the start of your fuel shortage cure....
HOHN |
Re:I got spanked
LMAO! Hence the post about high EGTs?
I'm about to test out some EDMs...I have run 275s, DD3s, and Super Mentals... Practice a few launches before the next race, and get those injectors and gauges in...he'll see your taillights! You could always get him on a roll, say part way through your 3rd gear.... ;D |
Re:I got spanked
4X4 will fix that problem! 8)
Re:I got spanked
remember also, u drive a nv4500 5 spd........not designed as a racing tranny
Re:I got spanked
[quote author=quantrill88 link=board=7;threadid=22833;start=0#msg214765 date=1069912072]
remember also, u drive a nv4500 5 spd........not designed as a racing tranny [/quote] That is a very true statement! I have seen Jason Burton (NW Custom) row through his as fast as about anybody I have ever seen.... :o |
Re:I got spanked
Rob,what size edms are you gonna try?I know you have 3s now.I have 2s and Iam interested in edms.keep us posted :)
Re:I got spanked
remember also, u drive a nv4500 5 spd........not designed as a racing tranny [/quote] Oh I dont know. I can shift it about as fast as a stone crusher. My biggest problem is about 10% of the time I miss getting it into third. Guess I need to practice ;D |
Re:I got spanked
[quote author=Rod meyer link=board=7;threadid=22833;start=0#msg214980 date=1069967896]
Rob,what size edms are you gonna try?I know you have 3s now.I have 2s and Iam interested in edms.keep us posted :) [/quote] I'm not sure. I need to discuss this more with some people with more knowledge on them than me. I am currently running super mentals. I like them, but for towing my DD3s were better. About the same power and heat, but with the 3s, I got almost 2 1/2 mpg better. That is with 14,000 lbs behind me. Same roads, same weather. |
