How much timing??
Old Jul 10, 2007 | 10:45 PM
deereguy07's Avatar
How much timing??
How do you know how much timing you need for a 180 pump? Im wanting to put laser cut dv's in it before to long. Going to pull with it a lil bit.
Old Jul 10, 2007 | 10:52 PM
Muddin_dude06's Avatar
I think on the smaller pumps (180, 160) you can run a little more timing than normal, I would say 18* with a set of headstuds would be ok. I popped mine with whats in my sig but as soon as I get done at the sledpull this weekend I'm tearing the head off...
Old Jul 10, 2007 | 11:37 PM
joshua smith's Avatar
i would like to know the same thing. I dont know what the stock timing is on the 180 pumps though. With what I have done on my 97 in my sig, I was giong to play safe and go to 14* at most, not 16 or 18*. can someone tell me if this would work ok?
1997 CTD 2500 4X4 ex-cab long box, 238,000 miles, gear vendors 8 speed overdrive, stage 5 TST plate, 4" exhaust, 370 injectors, full DTT auto trns, silencer ring MIA, X-monitor digital guages, 4:10 gears w/ limited slip, stock turbo and pump
Old Jul 11, 2007 | 01:03 PM
ssigmon's Avatar
on my 97 14* was stock. 18 should be just fine, I ran for an entire pulling season @ 22* with studs and stock head gasket. wasnt until i was planning to tear it down so figured what the heck bumped the timing to 28* and blew the headgasket at about 50psi of boost. Just curious
Scott
Old Jul 11, 2007 | 06:26 PM
deereguy07's Avatar
If you had the time set to 16* or 18* or so would the factory head gasket hold with a set of studs? Would factory gasket hold 14* with no studs?
Old Jul 11, 2007 | 07:06 PM
clutch1's Avatar
alot of guys are running around on 16* and never have probs, on the 215pump 14 is stock.
Old Jul 11, 2007 | 07:09 PM
clutch1's Avatar
with just a dv upgrade stay with 16* when you go with different injectors then you should go higher on the timing depending on the sticks.
Old Jul 11, 2007 | 08:29 PM
displacedtexan's Avatar
50k at 16.5* on a 215 pump, stock gasket/bolts.
AlCorr
28
Nov 27, 2008 10:05 AM
goose2w1
Aug 15, 2007 10:09 PM
06dmc
Sep 7, 2006 09:47 AM
ssigmon
May 26, 2006 03:54 PM
redhornet
May 28, 2004 06:06 PM
