how much timing
Old Jan 7, 2007 | 07:57 PM
Cummins Freak's Avatar
how much timing
just a quick question. i was told this weekend to only run about 12-13* of timing becasue of my 370's instead of the 15.5* im running now this is wrong right
Old Jan 7, 2007 | 09:02 PM
displacedtexan's Avatar
Who told you that?
Rick ran 16.5* with basically your setup (IIRC he had a 4k GSK) I see no real reason to back it off, if anything with the 370s you should have more bottom end which would help make up for the advanced timing.
Old Jan 7, 2007 | 09:15 PM
TxDiesel007's Avatar
Originally Posted by displacedtexan
Who told you that?
This is correct man...
Thanks Nick!
Cummins Freak, if you want a severe kick from the 370s and what not, run stock timing, it will hit you hard, but you will have absolutely no fun at all when u get to 2200 rpms cause u will start to run out of fuel... Without a GSK, stock timing, and 370s, well u just aint gonna have any fun...
Rick
Old Jan 7, 2007 | 09:22 PM
im not going to change it i just needed to make sure. i figured someone whos overvalved didn't really know anything antways hahahahhahahahaha JKJKJKJK
Old Jan 7, 2007 | 10:04 PM
wana12v's Avatar
that comment was probably made because the piston bowl does not match the 370 spray pattern (it sprays outside of the bowl) so the higher you time it the more it is amplified. however it will still make power spraying out of the bowl it will just white smoke more when cold.
AlCorr
28
Nov 27, 2008 10:05 AM
goose2w1
Aug 15, 2007 10:09 PM
06dmc
Sep 7, 2006 09:47 AM
ssigmon
May 26, 2006 03:54 PM
redhornet
May 28, 2004 06:06 PM
