Guages are in the new truck
Old Apr 20, 2003 | 02:45 PM
GrandpasRam's Avatar
Thanks, Rod, at Wilcat Diesel. All the parts came in last week, thanks to Rod, and I put everthing in yesterday. It took 12 hours since I take my time and look before I leap, but everything is in and working very well. The most difficult piece was to get the pillar mount replacement screw back into the threaded hole, but it finally went. Pyro installed pre-turbo was probably the easiest. Turbo replacement bolt from Piers was the most difficult due to the fuel rail being so close to the manifold bolt it removed to place it in - ended up having to disconnect that one injector rail to move it out of the way. Fuel pressure guage was not a problem either, ounce I figured out I could access the banjo bolt from the wheel well on the driver side. The most persistent problem was finding the instrument cluster lamp dimmer wire in the headlight switch to tie the gauge lamps into it. All done and looks and work fine. Thanks again Rod, and I'm glad I didn't have to leaave you any phone message Saturday.
Old Apr 20, 2003 | 06:21 PM
FiverBob's Avatar
Re:Guages are in the new truck
Grampa,<br><br>Did your gauges come in a blue sheep wool box like mine? Got it hanging on the wall to throw darts at it. <br><br>MissedAgainBob
Old Apr 21, 2003 | 07:23 AM
MissedAgainBob, I wondered what all that blue stuff was packed in the box........I guess that is why they have all those blue sheep - to grow their own box packing material..
QIK2D
Jan 28, 2012 05:28 PM
BurrisWill
May 8, 2009 11:56 AM
snowmanx
16
Sep 29, 2008 07:49 PM
CaledoniaOutlaw
Jan 30, 2008 01:32 PM
6speedcowboy
Jan 5, 2007 05:47 AM
