Upgrades for a 12 valve auto
Old Apr 17, 2003 | 10:55 AM
kennywayneracing's Avatar
My warranty will finally be running out within the next couple of months and I would like to start making some modifications. Right now, the truck is basically stock with the exception of a K&amp;N filter and straight pipe. With the auto tranny, I'm hesitant to do extensive modifications. I've been thinking about adding the following:<br>1. Boost, pyrometer, tranny guages<br>2. Scotty air system<br>3. TST #8 plate<br>4. 4&quot; stacks<br>Let me know what you guys think. Your input is greatly appreciated. Thanks.<br>Kenny
Old Apr 17, 2003 | 11:12 AM
JCamper's Avatar
Re:Upgrades for a 12 valve auto
In terms of &quot;bang for buck&quot; I would forget the air system for now and go with Governor Spring Kit. It makes the truck really nice while towing. If I couldn't pull a hill in OD, and had to shift down to 3rd, it had plenty of power, but just kind of sat at 2500 rpm due to the stock governor springs defueling. That really limits your speed on steep hills. Egts are not an issue with my setup at all, which is basically what you are looking at, so I think for now the scotty system would be a waste of money. Have a good one. Oh, one more thing, my exhaust is completely stock, with cat still on. At our fueling level I don't think exhaust is a huge issue, but if anything you should have even lower egts even with the stock airbox. Jcamper
Old Apr 17, 2003 | 11:33 AM
berner's Avatar
I'll second what JCamper suggested. Piers said I could have probably gotten away with a #6 plate with the stock auto but I decided to play it safe until the &quot;tranny fund&quot; grows a bit. You could call Piers at Piers Desiel Research or Rod at Wildcat. Either one will give you great advice and not try to sell you something you don't need.
Old Apr 17, 2003 | 05:24 PM
BigBlue's Avatar
I second calling Piers or Rod. Great guys and will steer you in the right direction.
Old Apr 17, 2003 | 06:35 PM
VinDiesel's Avatar
Pretty good advice so far, so I'll throw in $0.02-<br><br>Gauges first.<br><br>If you're fairly tool-handy, you can put in a shift kit for $100.00 + shipping. Not a high power cure-all, but it will let you get away with more.<br><br>#6 plate<br><br>3K GSK<br><br>Then maybe the Scotty II air system (consider it almost necessary if you'll be towing much).<br><br>Have fun!<br>
Old Apr 21, 2003 | 07:37 AM
Thanks guys--I appreciate the help.<br><br>Kenny
Old Apr 21, 2003 | 09:22 AM
98rammer's Avatar
yes, definately get the governor spring kit. you shouldn't have to worry too much about the transmission. the main problem to worry about is the lock up clutch. don't slip it for a long time (like up a long hill) or then you will have problems quickly.<br><br>Tom
91.5CTDBanks
Aug 13, 2007 09:51 AM
HorseHauler
Nov 2, 2004 08:02 PM
DynamicalyUnstable
Aug 3, 2003 10:42 PM
xj2extreme
17
Feb 19, 2003 01:27 PM
MrDiesel
Nov 29, 2002 09:27 PM
