governor spring kit ??
Old Mar 25, 2003 | 11:48 PM
dieselcrazy's Avatar
want to get the 3000 gsk. who sells them and how much??? are they all the same ?? thanks,scott
Old Mar 26, 2003 | 12:12 AM
BigBlue's Avatar
Re:governor spring kit ??
Pier's sells them I think. Probably Rod also.
Old Mar 26, 2003 | 02:22 AM
WKener's Avatar
Yes, Piers sells them as does TST. They should all be pretty much the same as long as your not comparing a 3K to a 4K kit...<br><br>www.piersdiesel.com<br>www.tstproducts.com
Old Mar 26, 2003 | 05:34 AM
bulthisl's Avatar
The 3k kit is $150 ans so is the 4k kit.<br>But with the 4k kit the valve springs have to be changed also.<br>That will cost ya another $110 from Piers.<br>IMO go with the 4k kit. I love mine and if yer like me the 3k kit will just leave ya wanting more.<br>Its just like the rest of the bombing.<br>Ya Always Want More. ;D<br><br> : Eddie : 8)
Old Mar 26, 2003 | 08:11 AM
SjLingenfelter's Avatar
Has anyone heard of the 3.5k rev kit? Someone told me that someone makes them but I forgot who he said. Thanks for the help.<br>SD03
Old Mar 26, 2003 | 06:35 PM
are the valve springs for the 4k kit much trouble to install ?? whats involved ?? shadetree mechanic here not a pro by any means.....thanks guys, scott
Old Mar 26, 2003 | 08:37 PM
bulthisl's Avatar
Just need a good valve spring compresser and maybe a new set of valve cover gaskets if your havent been replaced in a while.<br>Of course you need to have the know how to adjust the valves also.<br>It takes a while cyl. #'s 5~6 are tight to get into.<br>If you do be sure to NOT drop a valve down on to the piston.<br>It's not as bad as it sounds if you are mech. inclined.<br><br> : Eddie : 8)
Old Mar 26, 2003 | 10:19 PM
dodgeman01's Avatar
I have the 4k kit but have not put the HD valve prings in yet. I have done a lot to the truck and have done most of my work on all my trucks. I'm a lil afraid to risk putting the springs in because I do not want to drop a valve down into the engine. I have asked around and have yet to find any really good directions on how to do it. Piers said they would send me directions but I have yet to get them. going to call again tomarrow.<br>DM01<br>PS go 4k<br>
Old Mar 26, 2003 | 11:11 PM
DF5152's Avatar
havent opened a Cummins but i would think it should be easy to do the valve springs. A gasser requires the use of compressed air in tothe spark plug hole to keep the valve up. If u do them with the head on. Im sure someone will correct me if im wrong but im willing to bet that there in no dish in the piston to speak of and that the pistion is within a few thousanths of the head when it is up top so all that is necessary would be to do each cylinder witht the piston up top.
Old Mar 26, 2003 | 11:49 PM
BigBlue's Avatar
Personally, I wouldn't want to rotate the engine by hand.
Old Mar 27, 2003 | 04:27 AM
bulthisl's Avatar
It's not a big prob. the piston will hold it up.<br>You just got to rotate it right.<br><br><br><br>DM01 if you are comming to Frankfort on the 18th I'll explain it in detail then.<br><br>: Eddie : 8)
Old Mar 27, 2003 | 10:56 PM
Got Smoke?'s Avatar
[quote author=bulthisl link=board=7;threadid=12752;start=0#120932 date=1048760840]<br>It's not a big prob. the piston will hold it up.<br>You just got to rotate it right.<br><br><br><br>DM01 if you are comming to Frankfort on the 18th I'll explain it in detail then.<br><br>: Eddie : 8)<br>[/quote]<br><br>Hell if you do that Aaron will want you to do it!
Old Mar 27, 2003 | 11:06 PM
dodgeman01's Avatar
[quote author=Got Smoke? link=board=7;threadid=12752;start=0#121307 date=1048827360]<br>[quote author=bulthisl link=board=7;threadid=12752;start=0#120932 date=1048760840]<br>It's not a big prob. the piston will hold it up.<br>You just got to rotate it right.<br><br><br><br>DM01 if you are comming to Frankfort on the 18th I'll explain it in detail then.<br><br>: Eddie : 8)<br>[/quote]<br><br>Hell if you do that Aaron will want you to do it! <br>[/quote]<br>SHHHHHhhhhhh don't tell him that. <br>DM01
92smokin blacky
Oct 3, 2010 07:21 AM
ride_a_hd
Mar 14, 2005 05:21 PM
mhuppertz
24
Oct 1, 2004 08:41 PM
Dargo
16
Jul 5, 2004 12:10 PM
