Got me some gauges... now what?
Old Jan 15, 2004 | 12:17 AM
Dr. Evil's Avatar
Originally posted by Beach n Dodge
One quick question, kinda new to modifing CTD's. Is there any advantages in putting Pryo before the Turbo??? In all of the Turbo cars i have raced everone runs it after the turbo
Thanks for the info
Pre turbo give you a much more accurate temperature measurement. If it is post turbo, you are basically guessing the temperature.
Old Jan 15, 2004 | 10:48 PM
Beach n Dodge's Avatar
Thanks for the input, But wouldnt it be better 2 remove the turbo before drilling the manifold i would be kinda scared of drill filings. will the magnet thing work for the long haul? just curious
Thanks
Old Jan 16, 2004 | 12:19 PM
DRM's Avatar
DRM
We pre-drilled a pilot hole w/ grease on the bit. We then greased the main fitting bit, wiping the surface clean at intervals. One through, I used a magnetized screwdrive and fished around in there removing soveral chunks of metal that did get free of the grease. I quit when I stopped pulling metal back out on the magnet. Then a greased tap to run the pipe thread in there, and a little more fishing then we called it done.
Old Jan 16, 2004 | 12:46 PM
infidel's Avatar
After seeing two turbo impellers that were warped after drill chips stopped them dead and the exhaust overheated them I always remove the turbo now.
Guess I shouldn't say remove, I just remove the four bolts that hold the turbo to the manifold and slip a piece of cardboard in-between. After drilling and tapping start the engine for a couple seconds to blow the chips out, make sure airfilter is in place as chips will fly. It's actually faster this way than fooling around with grease and magnets, plus you are certain all the chips are removed.
Old Jan 16, 2004 | 07:41 PM
Thanks for the input. I think I to will be removing the Turbo.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
bhoff1175
Jun 7, 2006 10:19 PM
ChrisM55
May 11, 2005 01:47 PM
