Got my gauges, now some ???
Old May 10, 2005 | 07:19 PM
ChrisM55's Avatar
I noticed that first off my boost is not doing what I would of expected. It sits at 0 until I get on it, runs about 4 or 5 when cruising but I can't get it above about 18 or 19 at all. Does it sound like a leak? and if so, how would I test it?
Next ? is about my EGT's , should I be ab lto get them up around 1100 at an unloaded wot run?? they sure do come up fast!!
Sorry about the newby questions,
Chris
Old May 10, 2005 | 07:26 PM
ramtd02's Avatar
well if the turbo isnt elbowed, or turnbuckled, then yes your boost sounds perfect. As for the egt's 1100 on an empty wot run with your VA box, that sounds about right. Once you get a boost fooler and elbow or turnbuckle on their, then the boost will come up and egt's will go down. Keep in mind, that these trucks can take 1450 for short bursts!!
Old May 10, 2005 | 08:25 PM
ChrisM55's Avatar
I was told the VA bok was a boost fooler, is this not right?? Also, please explain elbow and turnbuckle?? I know it has to do with the waste gate but I don't know which I would need.
Thanks
Chris
Old May 10, 2005 | 10:44 PM
ramtd02's Avatar
well if you have a manual, then you put in the boost elbow in the turbo casing at the line that goes into the wastegate. This elbow is a 90* brass fitting that has a pin hole in it, so that way the boost is slower too reach the wastegate. If you have an auto, then you need too turnbuckle the waste gate shut. The turnbuckle is about 4 bucks from a local hardware sotr. The one i had too use was a 5/16".
If the VA box is a boost fooler then you wont set an overboost code. If it isnt then when you step on it, you will get an overboost code which you will have too reset, by disconnecting the batteries.
Old May 11, 2005 | 08:25 AM
Mopar1973man's Avatar
Re: Got my gauges, now some ???
Chris
Chris,
Your right on the money for a stock setup.
Under full throttle WOT I can get 1150*F and boost is about 19.5 PSI (Max Pressure of Wastegate).
Cruising the EGT is about 600-800*F and boost is about 5-10 PSI. (rolling hills)
In town (35 MPH) EGT is about 400-500*F and boost is about 0-2 PSI
YOUR GOOD!
Old May 11, 2005 | 12:59 PM
ChrisM55's Avatar
thanks guys!! Just found out from my brand newFP gauge my lift pump is toast!!!! Off to Cummins I go, now I have an afternoon project.
Chris
Old May 11, 2005 | 01:47 PM
Mike D's Avatar
99 autos will use a boost elbow too.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
bhoff1175
Jun 7, 2006 10:19 PM
DRM
19
Jan 16, 2004 07:41 PM
