Autometer Air Pressure Gauge???
Old Jan 16, 2004 | 03:56 PM
pmtg's Avatar
I would like to stick with the same style of gauges in my gauge pod. That being said, I am trying to stick with the Autometer Phantom gauges, but their 2 1/16" boost gauge only goes up to 35psi. Only the 2 5/8" gauge goes up to 60psi, but will obviously not fit the pod. I did notice on the Autometer website of a 0-150psi Air Pressure gauge that comes in 2 1/16". What do you guys think? Does this sound reasonable? Or won't it work for our applications? I have yet to call them, just wondering your ideas. Thanks a lot for the help, Pat
Old Jan 16, 2004 | 04:59 PM
infidel's Avatar
You didn't say what you're going to use it for so I'll assume boost.
150 would be way too high, you would only be getting readings in the lower eighth of the gauge most of the time.
Old Jan 16, 2004 | 06:51 PM
j's Avatar
j
put your info in your sig also, that way people know what kind of truck you are using this for. stock boost on my 02 only hits 19-20 psi. my boost gauge goes to 30 psi and is adequate for my needs. some people get the bombing bug and swap turbo's and do other high performance things and require a gauge that goes higher.
Old Jan 17, 2004 | 01:08 AM
BPonci's Avatar
I run a autometer air pressure gauge.Yhe only thing i don't like about it is that it starts on 0 psi and first line is 10 psi.Otherwise it works great.
ado2b1
Jul 6, 2007 10:27 PM
Dieselcamper
Feb 23, 2006 08:07 PM
rjm022
15
Feb 3, 2006 09:35 AM
ASTAR
18
Feb 3, 2006 09:27 AM
Buckshotmckee
Jan 27, 2005 09:48 AM
