gear ratio for racing or pulling
Old Dec 19, 2003 | 07:14 PM
Mostwanted's Avatar
What ratio do you drag racers go with? Pullers?
Old Dec 19, 2003 | 08:05 PM
joefarmer's Avatar
Re:gear ratio for racing or pulling
Just a guess, but I bet it's somewhat split over which transmission is in front of the gear ratio.
For example, my truck has 4.10s with a 5 speed. The 5th gear ratio is .75 so that makes my 4.10s final drive ratio 3.075. However, if I had a 47RE, over drive is .69 * 4.10 is 2.829.
Using 245/75/16 tires, this translates to 103 MPH for the auto and 94 MPH for the 5 speed at 3200 RPM redline for the same 4.10 rear end. For drag racing, this is a huge difference.
The other thing that makes a big difference is tire size. I like my 4.10's because I can run 35's or 36's eventually and not worry about lugging the engine. I do hate running at 2500 RPM to run 70 MPH down the highway now with my 33's but I think it's worth it in the long run.
Oh. To kinda halfway answer your question, I plan to both sled pull and run my truck in the 1/4 once or twice to see what it will do with my 4.10's. ;D
All the MPH/RPM/gearing info was obtained from Dave Fritz's site
brandon.
4969joes
Mar 27, 2010 08:58 AM
CaptainChrysler
Aug 18, 2008 11:36 PM
dog rocket
Oct 16, 2007 01:05 PM
d0dg301
May 15, 2006 10:36 AM
PourinDiesel
Nov 10, 2002 07:20 PM
