Gauges installed......... now what?
Old Mar 11, 2007 | 09:47 PM
Fullsizeyota's Avatar
i installed a pyro, tranny and boost gauge in my 99..
tranny isn't totally working, as it got dark before i could finish the job
anyway...... EGT's are around 400* empty just driving around town. getting on a steep freeway on ramp, the hottest i could get it up to was 900*
around town if i lay into it at a stop light, i may see 15 psi of boost.. on the same freeway on ramp, they highest it got was around 23 psi. just flat surface streets i see 1-5 psi
i tow a lot with this truck (2 times a month, 350 miles each way, around 8K-15K)
i have a K&N drop in filter and Edge EZ.... and i think i need a boost elbow? when i hit 23 psi, it seems like thats all it'll put out. RPMs keep climbing, but boost flatens out..
will the added boost help or hurt my EGTs when towing? should lower them, right?
Old Mar 12, 2007 | 12:10 AM
Tate's Avatar
Where's your pyro mounted? Pre or post turbo? I don't know how the auto would differ in the pyro readings, but I can get up to 600 just running up to 4th gear in town. Thats going real easy on it. Might get 1 or 2 psi of boost.
Boost is only gonna help you if you have hot EGT's. If they are within reason, no need to add more boost. If it gets hot towing, then a boost elbow wouldn't hurt.
BTW, do you have a fuel pressure gauge on the way?
Old Mar 12, 2007 | 12:13 AM
Pre turbo.
i have a DTT tranny... it really locks up good. it'll lock up around 45 and i can hammer the throttle and the egts are solid..
for some reason i thought the boost elbow was standard equipment with most chips/tuners.. but i wouldnt know, the truck had the EZ when i bought it.
Old Mar 12, 2007 | 12:20 AM
sorry i forgot..
no FP gauge on the way........ as of yet. i just installed a campaign pump from Cummins about a month and a half ago.. checked the FP on the schrader valve and i had about 10 PSI while idling. since i dont have major fueling mods, i figured i would be able to squeeze by with it for a little while. i have been checking it here and there and the pressure has been the same
Old Mar 12, 2007 | 01:54 AM
Ph4tty's Avatar
10 at idle is not so great. You might be at 1/2 that when you get into it.
Old Mar 12, 2007 | 10:06 AM
fade94's Avatar
I installed my pyro yesterday. On my truck, slightly built auto, I sit at 600-650 doing 65 mph. On ramps or accelerating will push it to 900. Haven't towed with it yet.
Kman9090
29
Dec 6, 2007 06:43 PM
rockhound
Nov 4, 2006 01:37 AM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
Minnesota-Corey
Jan 28, 2005 05:23 PM
