installed the gauges now i need a suggestion
Old Nov 2, 2006 | 08:28 PM
rockhound's Avatar
i installed the pyrometer and boost guages
i dropped the exhaust collector from the manifold in order to collect my drill shavings
cannot seem to get the collector to seat on the gasket now
i can hear the exhaust escaping when i spoll the trubo and reach about 20 lbs of boost
there is a soot line at the gasket
any suggestions as to a tool to tighten the outboard bolts
i can't get enough torque with my wrench that will fit in there
Old Nov 3, 2006 | 09:16 PM
BlackSheep5's Avatar
looks like you might have to go buy some new wrenches or something that will work.
Old Nov 4, 2006 | 01:37 AM
rockhound's Avatar
smarty
it turns out that the small amount of soot that i saw on the collector wasn't my problem, i had fixed that already i just didn't know it
i saw the soot and immediately thought that was my problem
keep it simple stupid is always a good way to go
turns out that somehow in my attempt to tap the manifold i managed to knock my aem intake out or at least loose from the rubber boot above the turbo
the horrible screech was the air rushing past that rubber seal when i built up boost
the obvious problem doesn't always solve the issue
oh well i can live with the small inconvenience of torqueing and retorqueing
the collector after finding the easy to fix problem, i really thought i may have screwed up my turbo with metal shavings from the install
Kman9090
29
Dec 6, 2007 06:43 PM
Fullsizeyota
Mar 12, 2007 10:06 AM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
Minnesota-Corey
Jan 28, 2005 05:23 PM
