Gauges
Old Feb 7, 2005 | 07:07 AM
Barefoot88's Avatar
gages
installed them sat. need to know if the readings are ok running at 50 pyro at 500 fuel at 13.5, boost at 2.5 psi at 60mph pyro at 650,fuel at 13.5 boost at 4.5 is this normal or there any problems
Old Feb 7, 2005 | 07:19 AM
Shovelhead's Avatar
Administrator / Scooter Bum
They sound about right for a pre-turbo probe Pyro 24 valve Cummins.
Old Feb 7, 2005 | 07:31 AM
Barefoot88's Avatar
shovelhead
does the boost sound right or is this little low
Old Feb 7, 2005 | 08:43 AM
Mechanos's Avatar
The boost gauge is basically a "gettin' it" gauge. If you are cruisin' along with throttle barely cracked and not working the engine, then the boost will be really low like that. Now, when you turn onto the accleration ramp to the freeway and punch it, you should be building much more boost there. Max. is about 20 psi +/- for a stock wastegated turbo.
Old Feb 7, 2005 | 09:17 AM
Shovelhead's Avatar
Drop 'bout 15,000 pounds worth of trailer behind the truck and see what happens to those boost numbers.
On level ground, at cruise, my boost numbers are pretty low too.
Keeping the boost numbers low will help get better fuel milage.
If I hammer the loud pedal under load, I'll see ~ 27 pounds.
Old Feb 7, 2005 | 11:23 AM
Barefoot88's Avatar
thanks guys again good info its hard to beat this site very friendly and down to earth prople
kiley
Old Feb 10, 2005 | 12:07 AM
Kyle Graham's Avatar
Kiley hows it going guages installed ok I see. Those numbers all look good talk to you later,
Kyle
Old Feb 10, 2005 | 12:07 PM
Barefoot88's Avatar
kyle
gages went in fine got the las pod last night for the trans went in ok every thing went well very nice set up some one needs to make a pod that replaces the factory one for a better fit for gages and wiring other than that is fine thanks
kiley
Old Feb 10, 2005 | 01:41 PM
You must be talking about the autometer steering column pod yeah I agree if it would replace and not overlay that would be nice.
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
estesbubba
Jul 18, 2006 04:35 PM
AggiePhil
Jan 30, 2005 01:15 PM
