Fueling upgrade question
Old Feb 1, 2007 | 10:23 PM
HOdiesel80's Avatar
Hey all, I am wanting to upgrade my fuel dilivery system. I have read a few posts and have decided to go with a holley blue as a pusher pump through my currently working stock lift pump. My question is can I upgrade my banjo fittings with regular brass plumbing fittings from home depot? I will buy about 15 ft of 1/2" fuel line to use also.
Old Feb 1, 2007 | 10:36 PM
blackdiesel's Avatar
Registered
why do you need to uprade your lines? im pushing over 500 hp on my stock lines and a holley blue
Old Feb 2, 2007 | 05:03 AM
HOdiesel80's Avatar
Okay, so just cut the line by the tank and attach the holley blue to the frame? Do I need the bigger banjo fittings/brass fittings?
Old Feb 2, 2007 | 12:37 PM
Ph4tty's Avatar
Lines and high flow fittings help keep the fuel pressure from dropping as quickly. Some people have even drilled out the stock banjos. Less restriction and more volume are good, but like BD said you might not need them if you're running dual pumps.
Old Feb 2, 2007 | 12:44 PM
Registered
i just cut the line by the tank and installed the blue. Grounded it under the bolt that held it on and ran the hot up to the fuse box
Common
May 29, 2007 03:47 PM
dws35
May 8, 2006 12:33 PM
96RAM
Dec 12, 2005 10:50 PM
apache
13
Mar 11, 2005 02:55 AM
Thrust
Oct 12, 2004 08:28 PM
