Fuel Pump Questions
Old Dec 9, 2006 | 10:51 AM
jeeptjstud's Avatar
Fuel Pump Questions
I have the bullydog fuel pump installed on my truck and would idle around 23psi and about 14psi WOT , I was getting on the freeway yesterday and lost fuel for about 2 seconds. My fuel pressure now idles at about 18 psi and at WOT drops to 0 psi. I can hear my aux. pump pumping before I start it, is my stocker shot? How can I test it?
Old Dec 9, 2006 | 10:54 AM
scottsjeeprolet's Avatar
Sound like your stock LP is dead, change it out and do the filter while in there.
Old Dec 9, 2006 | 10:56 AM
jeeptjstud's Avatar
Is the pump in the tank on a 98.5 or up by the engine?
Old Dec 9, 2006 | 11:51 AM
Talking
Unless you let the dealer change your pump it should be on the engine right behind the fuel filter. If the dealer retrofitted it then your pump might be in the tank.
here is a good site and a pic of your engine.
http://dodgeram.org/tech/dsl/mt_2_fe...l_sys_comp.htm
Old Dec 9, 2006 | 11:58 AM
wildwood2500's Avatar
I just changed my lp and my psi is 10 idle 8 wot. i put the cummins pump on it. Not the in tank junk.is this right? psi
Old Dec 9, 2006 | 12:21 PM
Sounds about right for the stock LP by itself. I'm sure if it should be more someone will chime in. I have the Bully Dog fuel management system with the stock LP still running and i get 23idle and 15wot.
Old Dec 9, 2006 | 12:28 PM
it used to idle at 15 12 wot.i just read about people having the screen in the fuel tank pluged and to blow air back into the tank to clear it out. what do you think ?
Old Dec 9, 2006 | 12:31 PM
iam going to go try it and see what happends,let you know findings
Old Dec 9, 2006 | 01:16 PM
well that didnt make any changes" but i tapped on the elect fuel presser sender and presser went up tp 13 at idle.shut it off, start it up back to 8 lb tap on it again back up to 13,think my sender is bad?
Old Dec 9, 2006 | 01:24 PM
piperca's Avatar
Get a mechanical FP gauge. It sounds like the sender is at least part of your problem. A stock pump should be idling around 14-15psi. Time to upgrade your fuel system, so you won't be posting similar posts in the not-too-distant future.
Old Dec 9, 2006 | 01:40 PM
would like to caant drop the $$$$$$$ right now
Old Dec 9, 2006 | 01:45 PM
piperca's Avatar
A nice AFS Big Dog System for Christmas would put a smile on any Cummins owner's face!
Old Dec 9, 2006 | 02:01 PM
all most got a fass,but that kit looks good,maybe after my 3 new grand kids are born? have 3 allready 11yrs 3 yrs and 3yrs old. the two 3 yrs old are 3 days apart.. 1 due in feb,1 in july, 1 in aug. whoo.
Old Dec 9, 2006 | 05:13 PM
piperca's Avatar
Congrats on the family! Yeah, it's all about the kids this time of year. I've got three of my own, well, one you can call a kid, the other two are well on their way to making their own way ... boy, doesn't time fly! And I know about the b-days too. My two youngest are at the beginning of the year ... never ends!
6 2 Carl
Nov 27, 2010 09:55 AM
DART505
Jul 29, 2007 05:03 PM
Stevie G
13
Aug 4, 2006 10:27 PM
gman07
Apr 15, 2006 08:32 PM
Commatoze
19
Aug 8, 2004 09:57 PM
