Fuel pressure slow to build after relocating LP
I installed a Vulcan big line kit last night a mounted a new LP as close as I could get it to the tank. I can't find any leaks but it takes 30 secs. to a minute for me to build any fuel pressure after the truck is started. I can bump the starter and I hear the pump running but no pressure is built. Is this normal or am I sucking air somewhere?
I have the vulcan kit and have had no problem such as yours. I would check the suction line, to make sure it is not sucking air, also, make sure the air is out of the system after the pump, maybe crack the fuel filter canister to bleed it. Could your LP be on its' way out? I have been very happy with my retro! It has solved my pump problems so far!
No afiliation, just happy!
Bob
Bob
Brand new LP was part of the install, no needle valve, just a snubber.
Once the system builds pressure it stays at ~12-14psi, even at WOT (empty). It just takes time to build pressure. I am going to try another hose clamp on the 3/8" line connecting to the stock hard line tommorow to try and eliminate any possible suction of air.
I just installed the Vulcan big line relo kit and had a problem starting the engine after a couple of cycles of the LP. No fuel. The pump ran and ran sounding like it was not pulling/pushing fuel. As it turns out, I had below a 1/2 tank of fuel, I was parked with the front end up hill about 5% and the pump would not prime. I simply added 10 gals to the tank and Then I could hear the pump bog down with fuel (which I didn't hear when it was sucking air). It works fine now. Just be careful NOT to run the FP too long with no fuel inside. I have a feeling this is why some folks burn their brand new pumps out so quickly. No prime, no fuel, just the sound of a high speed, dry pump.
regards, as always, jefe
I`m just throwing ideas out here, but did you bleed the fuel system after you did the retro kit. I`m sure you did, but it was just a thought.
Also, Wes, where are you in TN ? Just curious because there is a Mid TN TDR meeting this weekend in Dickson. You`re more than welcome to come join us if your interested.
I'm in Nashville, I have other obligations with weekend but I might check out a meeting one of these days.
Originally Posted by Wes in TN
When I installed everything I cycled the pump with the fuel bowl drain open until fuel started pouring out. Is there a better way to prime the system? I've put about 200 miles on it since installing the kit, I would think any air not being sucked into the system would have worked its way out by now?
Mmm, might want to bleed up by the IP, not at the btoom of the canister. (next time)
I'm thinking you have a guage plumbing issue, you should see some fluctuation from idle to WOT. I think after 200 miles your "air free", you've got another problem, not with the relo kit, not with the LP. I'd look at the gauge itself and related tubing/fittings.
