fuel pressure line
Old Apr 4, 2005 | 03:20 PM
HOdiesel80's Avatar
fuel pressure line
I've been doing some research on this site. For my fuel pressure gauge I want to use something sturdy that won't kink or leak. I have read a few posts about hydraulic hose. Is there something better? If I use hydraulic how long should I make the hose, and what fittings on both ends should I use. I have decided to use the same setup as Moose10's pics without isolator but with a needle valve. I will order Diprocal fuel, boost, and pyro. Any suggestions on a place with a good price tag.
Old Apr 4, 2005 | 05:57 PM
shoe's Avatar
Check them out I got my set up from them.
http://www.dieselmanor.com/
Old Apr 5, 2005 | 09:06 PM
HOdiesel80's Avatar
If I use hydraulic how long should I make the hose, and what fittings on both ends should I use, anyone?????
Old Apr 6, 2005 | 12:12 AM
ratsun's Avatar
Make sure if you use hydraulic hose its rated for diesel fuel! Not all hose is. My line was 5' but the gauge is mounted by the ashtray so for a pillar install you may need a bit more? The fittings will depend on what you have on the back of the gauge and your needle valve. The pic you show has a hose clamp on a push on fitting
Old Apr 6, 2005 | 12:40 AM
jimjawz's Avatar
I used grease gun and brake line. got adaptors from home depot.
see my pics for visual
Old Apr 6, 2005 | 01:38 AM
joefarmer's Avatar
I used Wildcat Diesel's hose that came with the FP gauge kit. It's 7' of braided stainless teflon hose. The hose should be available from any large truck supply store. You'll need to know the fitting size on the gauge and point you're tapping into the fuel system.
brandon.
dodgeguy71
17
Jan 19, 2012 12:52 AM
ctd4stan
May 18, 2009 02:56 PM
Tiara3100
Jan 14, 2008 10:06 AM
Sixpack73
Aug 21, 2007 10:51 AM
Flatty
Jan 5, 2005 02:50 PM
