fuel pressure guage
Old May 8, 2003 | 08:45 AM
winner172's Avatar
fuel pressure guage
I ordered a mechanical fuel pressure guage to test my lift pump and was wondering where is the best place to install it?
Old May 8, 2003 | 08:58 AM
GrandpasRam's Avatar
Re:fuel pressure guage
Mine's on a Pro Pod pillar mount.
Old May 8, 2003 | 09:24 AM
winner172's Avatar
I meant where is the best place to tap into the fuel system?<br>Sorry for the confusion
Old May 8, 2003 | 11:52 AM
Monty's Avatar
Since you will be putting the fuel psi gauge on a 12v. You might have problems with pressure spikes and premature failure of the fuel pressure gauge. This is due in part to the 12v's piston transfer pump (lift pump). It does not supply a constant psi since it rides on the cam lobe. I would put it at the outlet banjo of the filter. This is the banjo bolt on top of the filter closest to the front of the engine.
Old May 8, 2003 | 12:23 PM
winner172's Avatar
what kind of hardware will i need (fittings etc.)?
Old May 9, 2003 | 01:49 PM
winner172's Avatar
will i need some kind of adapter for the banjo? ???
Old May 10, 2003 | 08:04 PM
RCW's Avatar
RCW
A 12 valve Cummins is a tough one to get a guage to work with because of the surging of the transfer pump.<br><br>Cummins sells a replacement adaptor just for the attachment of a fuel pressure guage. It replaces the banjo bolt at the union of the fuel feed line to the injection pump. Then attach at least 18&quot; of high pressure hose (high pressure grease gun hose will work) between the adaptor and the sender to your guage.<br><br>If the guage sets there and bounces, you will need to install an adjustable orifice in between the hose and the adaptor. Then keep turning down the oriface size until the fuel pressure appears to hold steady and the needle vibration stops.
Old May 11, 2003 | 09:38 PM
1dslram's Avatar
I cut the supply line to the pump and installed a Tee in the line and then installed a snubber valve ( the same type of valve used for shut off on ice makers ect.) and ran braided hose to the gauge. All of this is available at Home Depot, Lowes or ? hardware store.<br>Bruce
Old May 12, 2003 | 08:37 AM
winner172's Avatar
Thanks
mytrucksaslug
Dec 16, 2007 01:11 PM
ScottMt02
Jul 27, 2007 07:04 PM
jgiachino
16
Jul 11, 2007 07:33 PM
bigragu
Jan 24, 2006 11:16 AM
Dodgezilla
15
Mar 11, 2003 07:49 AM
