fuel pressure gauge
Old 03-20-2005, 08:46 PM
upersleder's Avatar
i hooked mine up with hydraulic hose, it is rather cheap and mor dependable than the plastic or copper hose, i had it made up at napa.
Old 03-21-2005, 10:15 AM
2500CTD's Avatar
IS it 1/4 inch plastic tubing as well of 1/4 rubber line with the 1/8 inch inside??
upersleder, 1/8 hydraulic hose? Looking at one of these 2 ways. No problem with running diesel directly to the gage? No compatability issues? FP is my last gage, so really looking to get one SOON!!
Old 03-21-2005, 10:51 AM
Mopar1973man's Avatar
My guages are on there way... I think...
But I did NOT order the Isolator for it... I'm going to plumb straight to the gauge. Also going to add a needle valve so I can turn it off if I have to if the line leaks. But from all the people that have do this have never said anything about leaks or fire problems...
Old 03-21-2005, 10:57 AM
infidel's Avatar
Originally posted by RenegadeT
Good thinking, I'm preparing to install my gauges, I think I'll get some 1/4" for the fuel and boost. You didnt terminate the 1/4", just butt it into the 1/8" compression fitting? Maybe a few wraps of electrical tape or some heat shrink tube?
The line to my mech. oil pressure gauge in my Jeep leaked on my passengers foot. I thought it was pretty funny, but he didnt see it that way
It's just butted up. In fact if it's hard to push the 1/8" tubing though 1/4" cut the 1/4 into two foot sections then tape or shrink tube the sections together after it's all on.
Old 03-21-2005, 04:52 PM
upersleder's Avatar
mine was 1/4" hyd. hose with 1/8"NPT ends on both sides, i couldnt find a needle valve and was in a hurry, and others suggested a rubber line inbetween, so i used a tecumseh fuel valve for a snowblower to act as my needle valve, hooked a rubber line to it and then to the hyd. line into the cab, i wanted SS braided line but could not find any. its working so far, i havent gotten the pod i want yet, we'll see how it goes when i do. i found a racer site, you can order SS brake line, thats probably what i will end up with in the future.
dodgeguy71
17
01-19-2012 12:52 AM
Igor
09-13-2005 12:47 AM
Greeds22
25
09-11-2005 03:13 PM
engcogod
17
02-03-2005 08:49 PM
Patriot_RAM
10-08-2004 06:10 PM
Quick Reply: fuel pressure gauge
