View Poll Results: Which fuel kit is better and why?
FASS no filter system just the pump 95 GHP
21.95%
Scotty Smart Fuel Kit
19.51%
BD-Power Dodge Lift Pump Kit (Auxiliary)
14.63%
43.90%
Voters: 41. You may not vote on this poll
Which fuel kit to get?????
Old May 4, 2006 | 03:36 PM
QWKRTNU's Avatar
Which fuel kit or fuel pressure upgrade kit to get?????
Why it is better than the other?
Old May 4, 2006 | 05:00 PM
QWKRTNU's Avatar
what are the others if you put a vote there
Old May 4, 2006 | 05:13 PM
Buckshotmckee's Avatar
What are you going to put this fuel system in or do with it when you get it?
Old May 4, 2006 | 05:16 PM
QWKRTNU's Avatar
It is going in a 2001 3500. We put the edge with monitor on it yesterday and the fuel pressure is too low.
Old May 4, 2006 | 05:29 PM
P.J's Avatar
P.J
Your poll is a little unlcear, this is why I think the "other" catagory is taking over.
The Scotty kit doesn't replace a pump, just lines. Same with the Vulcan, a line and fitting upgrade with a relcation wiring harness and bracket.
Old May 4, 2006 | 09:13 PM
TNutcher's Avatar
My other vote is for a Machanical pump. Either a RASP or similar or a 12v lift pump type setup. To me the electronic is just one more thing to fail for a BS reason. Machanical is simpler, less wires. I know the others (FASS especially) is pretty dang reliable but still. Thats my vote.
TNutcher
Old May 5, 2006 | 06:47 AM
HOHN's Avatar
Scotty if you want to go a little cheaper (and don't need mega-hp).
Mechanical pump and aftermarket cam if you got the "big dollahs."
Old May 5, 2006 | 07:24 AM
XJJoe01's Avatar
I chose "Other"... I vote for the Vulcan kit since it replaces all the banjos and increases the fuel lines from the tank to the vp-44.
Joe
Old May 5, 2006 | 07:56 AM
RickCJ's Avatar
FASS!!! with filters!!!
Old May 5, 2006 | 08:02 AM
Bart Timothy's Avatar
If there's ever another time I have to replace a lift pump, it will be with the Walbro and dual ported external regulator. The trucks I've seen using this combination are running rock solid fuel pressures at any throttle setting. The Walbro has proved it reliability in countless other applications, and this truely is an inexpensive setup when compared to a FASS or RASP. It's cheaper than the stock lift pump, and a superior design to any other pump avialable.
Quite frankly, there's too much concern on this web site about fuel pressure on the 24v. The only times to be worried about it are if the pressure is less than 5 which shows there enough fuel being delivered, the pressure guage is bouncing which is a sure indication of eventual seal failure in the VP44, or you're trying to make big power and need lots of pressure.
Old May 5, 2006 | 11:21 PM
QWKRTNU's Avatar
where can I get this Vulcan kits at
Old May 6, 2006 | 01:19 AM
Ph4tty's Avatar
http://www.vulcanperformance.com/servlet/StoreFront
Old May 6, 2006 | 01:20 AM
QWKRTNU's Avatar
thanks for the location
Txwelder
14
May 5, 2013 01:49 PM
Bradleysram
19
May 12, 2009 08:36 AM
blackdiesel
Sep 5, 2005 12:17 PM
w4xtc
Aug 2, 2003 03:47 PM
