Front suspension rebuild????
I have a 2001 3/4 ton that needs a suspension rebuild. Does anyone make a kit for this? I would also like to gain a better ride out of it and maintain my current height with my leveler. I can probably do this myself but have no idea where the best place to buy the parts would be. I need new tires but don't want to put them on till this is done as it needs an alignment as well. Any help is greatly appreciated.
I would look at doing all of these.
steering box stabilizer, 3rd gen style trac-bar. the front steering linkage look at the 98-99 HD version that goes by cross over T style. you have a inverted Y style. or the newest talk is people are using the 2010-2011 steering linkage the same as the t style but beefier... if you wanting new control arms? there are many brands out there for a stock replacement.. fill out you info on what you have already on the truck. alot of these replacement items some can be pricey but they are worth it if you plan on keeping your truck for a long time.. do a search on here under all of the items I typed.. you can find alot of good reading on these items..
All of the above and throw in some Bilstein shocks, carli kore or pure progressive rate coil springs and some BFG A/T tires and you should have a very good ride.
Subliminal
12-13-2010 05:58 PM
case310350
06-23-2010 09:03 PM
mtnman006
24
09-08-2009 03:14 PM
