upgraded front end
upgraded front end
Gonna need some front end work in my 02 pretty soon. Wondering what kind of heavy duty front end parts are available. Like ball joints, axle joints, tie rods, wheel bearings, Tracbar, trailing arms etc
Timken wheel bearing is what I recommend. Proper torque is necessary to prevent premature bearing wear on the hub-to-knuckle bolts and the big axle nut. Rockauto had some decent prices last time I checked. Several options for a trackbar. I did a Luke's Link and it's been doing well. I'd probably go with a lifetime warranty one from Autozone if I were to do it again though. OR... I'd do a 3rd gen conversion. Thuren makes a 2nd gen track bar upgrade as well. Finally, I recommend getting a steering brace (aka stabilizer) while you're at it. Helps even out the force from the steering box onto both frames.
here is some good reading...It will give you all the T style part numbers..
https://www.dieseltruckresource.com/...e-t250591.html
hoffdog
0
Sep 21, 2010 08:53 PM
mikelr
Mar 8, 2007 07:05 PM
Gordonville
Apr 18, 2005 09:45 AM
royta
Jul 13, 2004 06:54 PM
