FP Gauge Install Questions
Old Apr 9, 2007 | 02:20 PM
lukem86's Avatar
I am no mechanic, but thought I would try to do the FP gauge install on my own after 2nd IP failure.... I havent started yet but was looking things over and I'm stuck already....
Is there an easy way to get at the bottom of the fuel filter housing so I can get the new banjo bolt into place to get started?
Thanks
Old Apr 9, 2007 | 04:15 PM
Homestead's Avatar
Take the canister right off the motor and do it on the bench. Easy as pie.
Jeff
Old Apr 9, 2007 | 08:02 PM
lukem86's Avatar
thanks jeff
Old Apr 9, 2007 | 08:10 PM
lukem86's Avatar
Another question...
I bought the ISSPRO gauge and kit from dieselmanor.... it came with the isolator, and 10' of airbrake hose, along with all of the fittings...
if i dont put the isolator on, and pick up a needle valve, is it ok to use that brake line hose right after the valve? or should I use the 3' of stainless braided hose and tie strap it furthur back away from the heat of the engine? and then go to the brake hose from the end of that and into the cab and gauge?
Hope that makes sense
motrapper
May 1, 2008 01:09 AM
Wicked500R
Mar 4, 2008 06:52 PM
spitfire9137
Jan 1, 2008 10:34 AM
ado2b1
Jul 6, 2007 10:27 PM
Maverick2001
Aug 19, 2005 12:33 PM
