Boost gauge install questions
Old Aug 19, 2005 | 02:30 AM
Maverick2001's Avatar
So I've got my boost gauge ordered from dpp and should be here tomorrow or saturday. Do I need to buy anything else for the installation? I've read that people have connected it to the block behined the fuel filter. Is there any special bushings or fittings I need to purchase before it gets here?
Thanks
Dave
Old Aug 19, 2005 | 12:33 PM
Mike D's Avatar
Yes, you have to get a 3/4" bushing to whatever size your boost gauge fitting is. You can get them at Home Depot or Lowes. Might take a couple of different fittings to get it to work. I think most boost gauge fitting are 1/4 npt?
http://plumbing.hardwarestore.com/52...ng-248609.aspx
Somthing like this to go into the block, then reduce down to a compression fitting.
http://plumbing.hardwarestore.com/52...on-195818.aspx
I was going from memory, but hopefully it will give you some idea of what has to happen to make it work.
Tank_66
Feb 28, 2008 08:34 PM
latitud_rt
Mar 24, 2003 11:31 PM
DawgII
Mar 10, 2003 07:15 PM
soundfetish
Feb 26, 2003 02:37 PM
