Fast Idle
Old Jun 1, 2007 | 12:45 PM
gyman98's Avatar
Fast Idle
Anyone have a fast idle on their 12v? Ho'd you do it?
I have a pull cable but hate it. One of my friends found a solenoid and a chain and it works good but he can't find anymore of them
Old Jun 1, 2007 | 01:06 PM
dodgezilla04's Avatar
how about a cruise control motor from a junkyard and the little chain? use a spring loaded switch(center off) to move the motor each direction?
Old Jun 4, 2007 | 12:17 PM
gyman98's Avatar
possibly never thought of that. Aren't they vacuum operated?
Old Jun 4, 2007 | 12:30 PM
not all. i think some of the gm's in the 90's were electric. since you have a stick i see your concern.
Old Jun 4, 2007 | 08:25 PM
Ocmechanx's Avatar
Use an electic motor connected to a screw drive that acts directly on the throttle linkage, thats how most of your heavy EQ with manual pumps set their throttle.
Or theres always a good adjustable PTO cable with center kickout they run bout 50$
Old Jun 5, 2007 | 12:23 AM
gyman98's Avatar
[QUOTE=
Or theres always a good adjustable PTO cable with center kickout they run bout 50$[/QUOTE]
Thats exactly what I have but I hate it, where would I find one of those screw motors?
Old Jun 5, 2007 | 08:45 AM
berner's Avatar
I used a solenoid from an old Rochester Quadra-Jet carb. I made a little bracket that bolts to two timing cover bolts. It won't push the trottle open but will hold it if I rev it up and activate the solenoid. The plunger length is adjustable so I can set the fast idle speed. I'll try to post a pic as soon as I can.
Old Jun 5, 2007 | 09:25 AM
gyman98's Avatar
Ok sounds good, Are you born and raised in saskatoon berner?
Old Jun 5, 2007 | 10:19 AM
berner's Avatar
Born in Lloydminster, lived here for the last 40 yrs. Are you close to here?
Old Jun 5, 2007 | 10:34 AM
gyman98's Avatar
No I'm about 140 miles south but there's lots of berners around here and alot of them are cousins of mine
Jim Lane
Dec 7, 2015 09:16 PM
EdmontonCanada
37
Dec 9, 2009 03:18 AM
trik396
Mar 14, 2007 07:57 AM
Pat-3500
17
Dec 3, 2002 06:13 PM
