exhaust housing question
Old Oct 13, 2005 | 10:52 AM
LanceD's Avatar
when you have a 14cm or 16 cm, or even a 26 cm housing, where exactly is that measurement taken from? and when you change housing sizes, do you have to change the exhaust turbine to match it?
Old Oct 13, 2005 | 11:20 AM
HOHN's Avatar
The size that's quoted is the total cross-sectional area of the two scrolls, measured just before they dump into the face of the turbine wheel. YOu can see just how restrictive and small the stock housings are when you run the numbers. The stock 12CM housing is roughly equivalent to a 3/4" hole
Housings are matched to a turbine wheel size. So if you have a housing for an HX35, it will work on ALL hx35s. (since they all have the same turbine size).
Old Oct 13, 2005 | 12:45 PM
LanceD's Avatar
so there is really no way to just measure a turbo and know what size housing is on it, or is there a formula? the scroll is the passage in which the exhaust gasses travel through right?
also, if you have a HT3B with a 22cm housing, and you want to put a 26 on it, all you have to do is change the housing, correct?
Old Oct 13, 2005 | 01:52 PM
signature600's Avatar
Yup!!
Chris
Old Oct 13, 2005 | 03:15 PM
Clunk's Avatar
The 21cm on my '92 had a number 21 cast on the housing. What's evidently a 14cm (non-stock big head) on my '01 has a number 14 cast on the housing.
Old Oct 14, 2005 | 05:18 AM
LanceD's Avatar
So what are the sizes of an HT3B in inches of the intake opening, outlet and exhaust outlet?
TJE
Oct 10, 2006 12:41 PM
ajbirken
Sep 6, 2006 12:11 AM
justagoodolboy
Jul 27, 2006 06:07 PM
95black2615
Jul 21, 2005 09:06 PM
HOHN
Dec 7, 2003 02:07 PM
