EGT sensor question
Old Mar 16, 2005 | 05:10 PM
shoe's Avatar
EGT sensor question
I am alittle confused on the location og the Exhaust sensor, I know it goes befor the turbo but I thought you should put it in the middle of the manifold so you could get a temp reading from all the cylinders verse putting it in the back or front or does it even matter? I thought I read that the manifold design you can not drill and tap the center in front of the turbo is this correct?
-Rob
Old Mar 16, 2005 | 05:20 PM
MtnCamper's Avatar
Correct, tap it to the side, measuring the back 3 cylinders. Tap it in the middle, and you drill thru the web of the manifold. Not good. Follow these instructions, and you should be fine.
http://www.tstproducts.com/pdffiles/instpy25b.pdf
Old Mar 16, 2005 | 05:21 PM
You can't put it in the middle, there's a dividing wall there. Most of us have it in the back.
Old Mar 16, 2005 | 05:23 PM
Lil Dog's Avatar
The exhaust manifold has an internal baffle to separate the front 3 cylinders from the rear three. Drilling the middle would be a big mess.
Use the TST instructions on their site or at PDR.
TST Requires ADOBE---> TST Pyro Install
PDR ---->PDR Pyro (TST notes)
Hope that helps...
J-eh
twincam2000
Jun 25, 2007 01:16 PM
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
durango12
Jul 12, 2004 04:42 PM
