Edge w/Attitude, boost fooler
I'm wanting to add an Edge w/Attitude to my 02 H.O. Will I need a boost fooler in addition to the Edge or will the Edge take care of this. I want the turbo to build 28-30 psi boost. I'm new to the "tuner" world so I'm not exactly sure how they work. I've also read about a "J hook" will I need this or can I disable the waste gate. I have a 12V and run it with the waste gate unhooked at 30-35 PSI. I picked the Edge because I like the gauges built in one unit. Thanks for any advice in advance..
Should do boost fooling on its own.
You should not need a jhook as you have have an HX35. You will need to put a different elbow on the vacuum line or block it some way. I think you should see more like 35psi or maybe a little higher so be careful.
Boost fooling incorperated with the unit. Auto's are wastegated at 20 psi and have a metal tube to supply the wastegate-I know some people who just piched it shut. Manuals have a rubber hose. The kit comes with a restricted brass elbow to repace the stock one which delays wastegate operation. Manuals are wastegate at higher psi, I'm not positive but somewhere in the 30-35 psi range.
Killdmycobra
Nov 12, 2010 05:15 PM
exwrestler
Nov 8, 2009 08:30 AM
bige124
Oct 8, 2009 09:06 AM
Rollin' Smoke
23
Jun 26, 2007 09:04 PM
goose2w1
17
Jun 8, 2007 09:04 AM
