Edge owners with gauges
What are your EGT's in the different settings ? I'm not sure if i will put gauges on yet. What do you get in setting 4 on a wot run empty straight hiway? Is there a point where you guys are close to thermo-nuclear meltdown ?
Re:Edge owners with gauges
I could get to meltdown stock, wot 2800 rpm pulling my 5er will get me to 1300 degrees on the gauge real quick, need to back off on go peddle. My opinion, EGT gauge should be standard equipment!! :
when you get your pyro gauge it will blow you away how fast the egt's rise....i wasn't going to get a pyro gauge B-4 i got the box either....man, i'm happy i did it in the correct order or i may have had meltdown....listen to these guys, GET at least the pyro gauge FIRST!!!
You guys are telling me that a bone stock truck pulling a load that it is totally rated for will cause it to run that hot on the EGT's, you would think that a bone stock truck could run all day long in those conditions,I'm very surprised that Cummins did not make the engine more fool proof EG: sled manufacturers commonly jet for worst case scenario eg -20f wot across a lake for 2 miles.Now is there a common place to put your thermocoupler or is it wherever you can get a drill in ? On a 2 stroke your thermocoupler always goes 6 inches away from your piston .
[quote author=hilclmr link=board=7;threadid=17198;start=0#161293 date=1058505004]
[/quote]
Check here for installation instructions for pre 2003.
The same general idea applies:
Pryometer Probe Installation
Now is there a common place to put your thermocoupler or is it wherever you can get a drill in ? On a 2 stroke your thermocoupler always goes 6 inches away from your piston .[/quote]
Kman9090
29
Dec 6, 2007 06:43 PM
kev94mx
19
Jun 15, 2007 07:33 PM
coontz0473
17
Sep 22, 2006 03:52 PM
