Edge Juice - Does it really work?
Old Feb 11, 2007 | 08:04 PM
BiggDogg's Avatar
I would like more power when towing my 5th wheel. I'm looking at using the Edge Juice to increase my power. Does it really work or is there others products better? If I do this modification what other changes should I do to my truck. (ie tranny work, gauges) I'm not much of a gear-head, so I can use all the advise I can get.
Thanks
Old Feb 11, 2007 | 08:17 PM
madhat's Avatar
Administrator/Jarhead
I'm pretty happy with mine, it seems to help, but you can only use it to level 2 for towing, anything else will make high EGT's. The edge had a very simple instal, and it is easy to use. Just my 02. There may be better towing boxes out there, tho.
Old Feb 11, 2007 | 10:09 PM
Adam3291's Avatar
First thing will be turbo, you can't do much with that HY35 turbo. Read my signature and you will see the set up I'm working on for towing. I got pretty much everything except a couple little things. I'm hoping to have it all put together to see what power she has with the RV275's and Edge EZ.
Old Feb 11, 2007 | 10:22 PM
skynyrd's Avatar
i would start with some gauges!! and go from there.
Old Feb 11, 2007 | 10:42 PM
cLAYH's Avatar
The Juice with attitude has all the guages you'll need which is why I went with it. If you keep it on the lower levels(2 is designated for towing) you shouldn't need any other upgrades provided you have a good lift pump setup(not the stock one no matter how new the pump is).
Of course this all dependes on how much more you really want!
Old Feb 11, 2007 | 11:15 PM
BiggDogg's Avatar
cLAYH this is going to be a stupid question but what is a "lift pump"?
Old Feb 11, 2007 | 11:26 PM
westexhunt's Avatar
Yea it works great, best buy in electronic diesel performance in my opinion.
Old Feb 11, 2007 | 11:50 PM
cLAYH's Avatar
The lift pump is the pump that pulls the fuel from the tank and pushes it to the injection pump. AKA: supply pump or fuel pump.
On these trucks its electric and prone to failure. The injection pump is lubed and cooled by fuel so if it runs dry then damage occurs and it fails and is about $1000 to fix. The most common scenario is for the lift pump to fail which starves the injection pump causing it to fail.
Do a search on "lift pumps" "VP44 failure" and "tapping the wire". This will educate you so you can make an informed decesion before buying the Edge.
Old Feb 12, 2007 | 07:02 PM
01smokin's Avatar
i can tow on level five with no problem
Old Feb 12, 2007 | 07:04 PM
blackdiesel's Avatar
Registered
how much weight though?
amartinson
51
Feb 22, 2009 02:05 PM
Fire Rescue124
Jul 9, 2008 08:48 AM
Redog76
22
Feb 6, 2008 10:32 PM
razor6
22
Jan 20, 2006 03:43 PM
