edge juice
Old Aug 6, 2006 | 09:01 PM
wrglrroper's Avatar
edge juice
I am thinking of getting the edge juice w/attitude. Can someone tell me if the pyro and stuff comes with it or do you have to get it seperatly.
Thanks
Old Aug 6, 2006 | 09:05 PM
4x4dually's Avatar
Everything comes with it. Buy it from Lary here at DTR. He has the best price.
I put one on last Thursday on my truck...love it.
https://www.dieseltruckresource.com/...d.php?t=111523
Old Aug 6, 2006 | 09:09 PM
wrglrroper's Avatar
Thanks for the info. there website says what it will do but that is all I saw. I am going to buy one tomorrow probably. Larry who sorry?
Old Aug 6, 2006 | 09:19 PM
4x4dually's Avatar
DTR members get the best pricing - - 304-952-6896 ask for Lary
It will take you a while, you'll know if you read my link I posted above. If you don't already have a pyro installed, you'll also have to drill and tap that. Just remember, DON'T DRILL IN THE MIDDLE OF THE MANTIFOLD. There is a web in there. Drill at the top of one of the crowns. I'm sure there are other threads about this....but I did mine several years ago....before I learned much about it...and found this website....and mine has a plug in the middle....right next to my pyro...duh!?!?!?!?
If you have any other questions, PM me. I'll be glad to help you at all I can. It is still pretty fresh in my mind.
Old Aug 6, 2006 | 09:25 PM
wrglrroper's Avatar
thanks for all your guidance I will keep you in mind when installing.
Old Aug 6, 2006 | 09:30 PM
4x4dually's Avatar
Just give me a shout....you'll love the map sensor plug!!!
FYI:
I wil only be able to check post in the late evening this week, I'm in VA on business.
Old Aug 6, 2006 | 09:34 PM
CTD01's Avatar
[QUOTE=4x4dually]Just give me a shout....you'll love the map sensor plug!!!
Did you unplug your map sensor with the juice? How I did mine it set a code no power it sucked. If you can do this tell me how, I unplugged it from the map sensor itself and no luck. Or are you just saying that its had to plug in the map sensor? Thanx,
Paul
Old Aug 6, 2006 | 09:42 PM
4x4dually's Avatar
[QUOTE=CTD01]
Paul
I unplugged the stock connector from the sensor, hooked the juice connector to the stock sensor, then plugged the stock connector that came off the sensor into the other connector on the juice harness. Those little red locking tabs that slide perpendicular to the connector are the pits to get off. The one on my truck was on the bottom of the connector so I couldn't see it from the top. I crawled under the truck with a very long screwdriver and a light and reached up and popped the tab out like that. This flat keyboard on this laptop is killing my hands!!! ARGH!
Old Aug 6, 2006 | 09:45 PM
CTD01's Avatar
Map
Oh I though you meant the unplugging the map sensor trick. Mine didnt have the red tabs , I know the one you mean though. Did you every try unpluggin the map sensor like the people do with the comps, didnt work for me. The juice with the attitude was the best thing I bought for my truck.
Old Aug 6, 2006 | 09:48 PM
4x4dually's Avatar
Gotcha. No, I never tried that. The Juice is the best thing I have done too....next month....the best thing I will have bought will be a new clutch. After that, the best thing will be injectors....."the road goes on forever, the party never ends"....(for you Robert Earl Keen fans)!!!!
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
djcheez
Oct 15, 2005 04:13 PM
